Hello everyone, I have several IKEA Hemnes furniture pieces, mainly dressers and nightstands, that I would like to protect from water stains. Since the wood is untreated and varnished, I am unsure how best to handle situations when a glass of water or a plant pot is placed on the surface.
My specific question is: What practical measures and possibly care products do you recommend to prevent ugly water stains on my Hemnes furniture? Are there certain impregnations, sealants, or regular maintenance routines that have proven effective? I would appreciate any tips and experiences.
Regarding marcdra’s question about applying an additional stain or sealant: Hemnes furniture is basically finished with a clear, matte varnish that preserves the natural wood character while providing protection. Applying another layer can increase water resistance, but there is a risk of altering the appearance, as colors or gloss levels may change. Additionally, thicker layers can sometimes cause stress in the wood, which may lead to cracking or flaking of the varnish. If you still want to make adjustments, choose products specifically designed for finished wood furniture and test them first in an inconspicuous area. Important: With consistent use of protective pads and regular maintenance, the protection usually remains sufficient without modifying the original finish.
cassandra21 Sep 2020 12:02marcdra schrieb:
Is it advisable to apply an additional glaze or sealant to Hemnes furniture to complement the existing IKEA finish?An extension or preservation of the warranty through additional coatings is generally unlikely, as IKEA does not plan for customer post-treatment. From a technical perspective, however, an extra sealant can improve protection against water stains but should be precisely matched to the original finish. Products based on polyurethane or hard wax oils are suitable, applied thinly and in several layers. It is also recommended to lightly sand the surface before application, although this is not always possible on painted surfaces. It is important that the character of the furniture is not lost during the process.
I think we should also question whether additional sealing is really necessary if simple protective measures have worked so far.
Water stains primarily result from standing moisture. If this is already prevented by using coasters and wiping up immediately, the extra work and material costs might not be justified. Additionally, after-treatment products can cause color changes or unwanted effects depending on their composition. So it’s better to rely on basic protection first before using more aggressive products.
taudi schrieb:
Prevention is better than repair, so always ensure there is a barrier between water and wood.
GU-LAU60 schrieb:
Not to forget: Regular ventilation and indoor climate also play a role.Exactly, maintaining a consistent humidity level and good airflow not only protect the furniture but also improve living comfort. The right balance is often an underestimated factor when it comes to preserving wooden furniture.
