Hello everyone, I am currently dealing with the challenge of protecting my Ikea Hemnes furniture from scratches caused by pets, especially cats. The HEMNES series is known for its beautiful yet relatively delicate painted finish on solid pine wood. I am looking for practical and visually acceptable solutions to protect the furniture long-term in a room with free-roaming cats, without completely rearranging the furniture or permanently restricting the animals. Are there any proven methods or materials that work well on HEMNES furniture? For example, special films, care products, or furniture covers? I am also open to preventative tips, such as pet training or providing alternative scratching options. Thanks in advance for your expertise!
I would especially recommend using clear vinyl scratch protection films. They are relatively easy to apply and protect surfaces from scratches without significantly changing their appearance. Additionally, scratching posts and alternative scratching areas could help redirect the cats’ attention.
Hello Tau-me, your concern is very understandable since the HEMNES furniture is indeed quite susceptible due to its surface. I would recommend the following multi-step approach:
- First, check if the furniture has been treated with a special wood lacquer or wax. Many solid wood products from Ikea are sealed with a thin layer of clear varnish, which only offers limited protection against scratches.
- Next, applying self-adhesive transparent protective films would be advisable. Make sure that the films are specifically designed for furniture protection and do not have aggressive adhesives that could damage the finish.
- Another option is so-called furniture or edge protectors made from plastic or soft rubber, especially for highly exposed areas such as edges and corners.
- Additionally, I suggest increasing your cats’ engagement with scratching posts or sisal mats, ideally placed close to the furniture. Cats tend to scratch where no suitable alternatives are available.
- There are also gentle repellents that can be applied to furniture, which have an unpleasant smell for cats without harming them. These should be used sparingly and carefully.
I would also be interested to know exactly what type of pets are involved, how many cats you have, and what their behavior looks like—are they scratching heavily or more occasionally? This information could help to further tailor the advice.
Laukau5 schrieb:
I’m also curious about the exact types of pets involved, how many cats you have, and what their behavior seems to be – heavy scratching or more occasional?Thank you for the detailed response. I have two cats, neither very active when it comes to scratching furniture, but they do like to mark the edges and occasionally have the habit of scratching the cabinet frames, which naturally wears down the surface. A scratching post is available but apparently not always used as the main scratching option. It is not just about scratches, but general wear that makes the wood look somewhat dull. I am quite knowledgeable about films from the trade and really want to use ones without aggressive adhesives, as I also want to avoid damaging the finish.
I’m also interested in whether anyone has experience with furniture care products that extend wood protection or that leave some kind of protective film.
Hello, I can only confirm that transparent protective films for furniture are a good first line of defense. It is important that the film can be easily removed without leaving any adhesive residue.
For surface care, special wood care products designed for furniture with lacquer finishes are recommended. These products seal the surface and create a water-repellent layer that refreshes the wood’s appearance and enhances protection. It is important to test them first in an inconspicuous area.
As Laukau5 already emphasized, targeted distraction of cats with suitable scratching furniture is often the most sustainable protection.
In my opinion, a combination of protective film and regular surface maintenance is the most practical solution. There are also furniture waxes with a light polymer film that make the surface more resistant.
barEsperan12 Feb 2018 09:56Tau-me schrieb:
I have a good understanding of films from my work experience and really want those without aggressive adhesives, as I also want to avoid paint damage.I attached self-adhesive felt pads to the most vulnerable spots on my HEMNES furniture myself. While they don’t offer 100% protection, they significantly reduce mechanical damage. They are barely noticeable and very gentle on the paint. Maybe a simple interim solution if you don’t want to use films.
