ᐅ How can I protect Ikea Besta units from moisture when using them in a bathroom?
Created on: 3 Aug 2023 14:27
Lotolis
Hello everyone, I am planning to put an Ikea Besta sideboard in the bathroom because I need extra storage space. Since the furniture is not originally designed for damp rooms and is made of engineered wood panels, I am concerned about possible moisture exposure and resulting damage such as swelling, warping, or mold growth. Does anyone have experience or tips on how to effectively protect a Besta in the bathroom from moisture? I am thinking of possible sealants, special treatments, or suitable placement options to minimize moisture impact. Thanks in advance for any help!
Domau0
4 Aug 2023 11:27
Hello Lotolis, some thoughts on comprehensive protection for the Ikea Besta in the bathroom:
1. Water absorption: MDF and particleboard are highly absorbent, so mechanical and chemical surface protection is essential.
2. Primer: Before applying the final paint, a moisture- and water-repellent primer is recommended to stabilize the surface.
3. Types of paint: Polyurethane varnishes or synthetic resin paints specially designed for use in humid environments provide the best protection. Make sure these products are specified by the manufacturer for wet rooms.
4. Edge treatment: As mentioned several times, edges must be manually sealed before painting, preferably with PU putty or edge guards.
5. Installation: Avoid installing during high humidity (e.g., right after showering), and keep the furniture slightly away from the wall afterwards.
6. Room climate: Constantly high humidity should be avoided by ventilation or using a dehumidifier.
7. Alternatives: If possible, consider replacing Besta components with systems featuring real wood veneer or solid wood, which are more resistant to moisture.
Question: What is the average humidity level in your bathroom – is it well ventilated? This greatly affects durability.
Lotolis
5 Aug 2023 08:39
Domau0 schrieb:
Question: What is the average humidity level in the bathroom – is it ventilated well?
Thank you for the detailed post! For your information: the bathroom has an existing window and a ventilation system, so ventilation is used regularly. Although the humidity briefly rises above 70% during showers, the window is opened afterward, allowing moisture to dissipate quickly. Persistent high humidity is generally not an issue.
Therefore, it makes sense to focus on sealing and edge insulation, combined with the mentioned spacing. It reassures me to hear that, with the appropriate treatment, this kind of use in the bathroom is definitely feasible.
CARLA
5 Aug 2023 14:22
In brief:
- Treat chipboard with at least two coats of moisture-resistant clear varnish
- Seal edges thoroughly, if needed using edge protection tape or polyurethane filler
- Do not place furniture directly against the wall; maintain at least a 5 mm (0.2 inches) gap
- Use rubber feet or spacers between the furniture and the floor
- Always ventilate well after use to quickly reduce moisture
These measures significantly reduce the risk of moisture damage. However, for consistently very damp rooms, specially designed furniture is recommended.
