Good morning everyone,
I am about to transport some IKEA Malm furniture and am looking for proven methods to pack these items securely to prevent scratches, dents, or other damage during the move.
I am particularly interested in the best way to protect the relatively smooth, lacquered surfaces—whether it is better to use special protective films, blankets, bubble wrap, or rugs—and how to secure the furniture pieces to prevent shifting during transport.
Perhaps someone also has experience with securing drawers and doors, or if it is advisable to remove them completely and transport them separately.
I look forward to any tips, experiences, or even step-by-step guides on how you carefully pack and transport Malm dressers or beds without damage. Thanks in advance!
Hey Brisa,
great question, I’ve moved Malm furniture a few times myself. My advice: always remove the drawers first and pack them separately – otherwise, they rattle during transport and can damage the furniture.
I usually use bubble wrap secured with painter’s tape – it sticks well without damaging the surface. Then I wrap a thin blanket or an old rug around it for extra cushioning.
Sure, it sounds more complicated than packing paper, but if you have Malm furniture that scratches easily, it’s really worth it. Oh, and don’t forget to use ratchet straps or tie-downs in the van to keep the furniture from shifting during the ride.
Good luck packing! 🙂
Hello Brisa,
to answer your question in detail, it is first important to know whether the Malm furniture will be transported fully assembled or if you are willing to disassemble it. The finish on the Malm series is particularly sensitive to scratches and dents.
Here is my detailed suggested process:
1. Disassembly: If possible, I recommend at least removing all the drawers completely and packing them separately in damage-proof boxes. The drawer runners are especially delicate and can easily become bent otherwise.
2. Preparation of the furniture parts:
- Lightly clean the surfaces to avoid trapping dirt particles.
- Use special furniture blankets with a soft inner layer (furniture felt) or thick cotton cloths as base protection.
3. Protective materials:
- Bubble wrap works well for heavily stressed corners but should not be used to wrap the entire surface directly, as it can generate static and leave adhesive residue.
- Use painter’s tape or special protective tape without strong adhesive. Avoid regular adhesive tape.
4. Securing:
- Once wrapped, use ratchet straps or elastic straps (with padding) to ensure the furniture parts do not shift.
- It is best to add foam padding where the straps contact the surfaces.
Could you share more details about the assembly and transport method? Vehicle type, distance? That would help me provide more targeted advice.
4. Securing:
Palenar schrieb:
whether the Malm furniture will be transported fully assembled or if you’re willing to disassemble it. I plan to at least remove the drawers and keep the larger pieces like the dresser and possibly a bed frame assembled so I can stack them more efficiently in my small van.
juMira46 schrieb:
Don’t forget tie-down straps in the van I hadn’t considered that yet, but it does sound very sensible.
I’m driving about 50 kilometers (30 miles) with my own van and want to avoid arriving at the new place with scratched furniture.
Is there anything else I should pay attention to when protecting the edges? The edges of Malm furniture aren’t really well protected.
As a supplement: The edges on Malm furniture are indeed delicate because they are usually covered only with a thin foil. A special edge protection profile made of foam, which can be found at any hardware store, is recommended here.
These profiles can be cut to size and securely fixed to the corners with painter’s tape. They absorb impacts much better than just a blanket or something similar.
Additionally, I recommend always positioning the furniture so that the edges face inward, if possible. This significantly reduces the exposed area during unexpected shifts in the moving vehicle.
When assembling the furniture, also check that all connections are tight. Loose screws could cause damage during transport.
