ᐅ How do I properly transport and secure Billy bookcases during a move?
Created on: 12 Mar 2024 08:47
Teoru
I am currently preparing for my move and facing the challenge of transporting my IKEA Billy bookshelves safely and without damage. Since the shelves are relatively large and rather lightweight, I am concerned about how to package them optimally and secure them firmly in the moving vehicle to prevent them from shifting or getting damaged during transport.
What is the best way to:
- Protect the shelf components (panels, backboards, etc.) from scratches, breaks, or warping?
- Secure the shelves so they neither tip over nor collide with each other during transport?
- Decide whether it is better to completely disassemble the shelves or at least transport them partially assembled?
I would greatly appreciate practical tips, experiences, and any helpful tools. Thank you in advance!
kasan
12 Mar 2024 13:07
klo61 schrieb:
1. Completely disassemble
I would like to offer a different perspective – is it really always necessary to completely disassemble the shelving? If you only partially take the shelves apart, you can reassemble them more quickly and reduce the risk of losing screws.
I also wonder if it might be better to transport the shelf boards vertically in the trolley. This could minimize bending stress on the boards – lying flat, they could easily bend.
I feel a more detailed consideration of the storage and transport position of each part is missing here.
What do you think? Completely disassemble or just remove the back panels and keep the rest assembled?
Teoru
12 Mar 2024 13:45
kasan schrieb:
I miss a more detailed consideration of the storage and transport position of the individual parts here.
Good point! My transport will be a medium-sized moving truck, so there should basically be enough space for upright storage. However, I lack experience regarding how sensitive the side panels are to vertical positioning.
Has anyone here had experience whether storing them vertically after disassembly offers advantages compared to stacking? Especially concerning deformation and stability?
Nabla64
13 Mar 2024 08:18
kasan schrieb:
I am also wondering if it might be better to transport the shelves vertically in the vehicle?
From my experience: Yes, storing the boards vertically is often beneficial because it reduces stress on the panels. When lying flat, there is a risk that individual boards may warp or break under the weight of others.
Requirements:
- The panels must be securely positioned, ideally against a solid wall inside the moving vehicle.
- Cushion gaps with soft materials (blankets, etc.) to prevent shifting.
Teoru schrieb:
Has anyone here had experience whether vertical storage after disassembly offers advantages over stacking?
I recommend vertical transport, especially for the back panels, which are very thin and fragile. Side panels can be stacked depending on available space, as long as they are properly cushioned.
Dustin
13 Mar 2024 09:03
Completely disassemble the shelves, protect each part individually, transport the back panels separately and upright. Collect screws in labeled bags. Secure everything in the vehicle with straps to prevent shifting or tipping over.
KAULIS
13 Mar 2024 10:34
Additional Information:
The load on the boards from the weight of other components should not be underestimated when stored flat. Particle boards can warp or chip if subjected to unfavorable pressure for extended periods.
Storing the boards upright reduces this mechanical stress. A secure fastening is essential to prevent them from tipping over.
A tip: When loading the moving truck, place the boards between boxes or bulky items to avoid sideways pressure. A small gap with felt or foam padding protects against contact and friction.
In summary:
- Complete disassembly recommended
- Protection using blankets/plastic wrap
- Upright position preferred if there is enough space
- Securely tie down to prevent tipping and slipping
- Organize small parts
