ᐅ How should I properly store Ikea Metod components before assembly?
Created on: 17 May 2021 09:12
Gapofra
Gapofra
17 May 2021 09:12
Hello everyone, I am currently planning the installation of my new Ikea Metod kitchen and have realized that the individual parts will only be delivered a few days before assembly. My question is: What is the best way to store the Ikea Metod parts before installation to avoid damage or deformation? I am especially interested in how to store the large fronts, carcasses, and drawer bottom panels in a space-saving and secure manner, in case the room is limited and the parts are installed in multiple stages. Are there any experiences regarding the optimal storage conditions (temperature, humidity) or the arrangement of the parts (for example, lying flat versus standing)? I would appreciate practical tips, especially for situations where not all modules are assembled at the same time. Thanks in advance!
Matthewt48
17 May 2021 09:46
Hello Gapofra, this is a very important question for anyone assembling in stages – it’s good that you bring this up.
Ikea Metod parts are generally quite sturdy, but fronts and drawer bottoms should definitely be stored flat to prevent warping. Cabinets can be stored upright with care, but make sure they don’t tip over or fall.
It is important to keep the parts dry and at room temperature – moisture can cause the boards to swell, and large temperature fluctuations are undesirable. If the storage area is a bit cooler but dry, that is also fine. Avoid direct sunlight, as it could cause surface fading.
If you have limited space, I recommend cushioning the parts well and placing them between large, sturdy cardboard boxes or blankets. Do not stack fronts too high to avoid pressure marks or minor deformations.
In short:
- Store fronts and drawer bottoms flat
- Store cabinets upright, but stable and secured
- Storage environment should be cool, dry, and not exposed to sunlight
- Cover and cushion well
This way, you protect the parts from damage in the best possible way.
koduga
17 May 2021 11:03
I completely understand why you're asking this question. I had a similar issue last year because I assembled my kitchen in several stages and had to store the parts for a few days in between.
I can only confirm that! At first, I leaned my fronts upright against a wall, and after some time, one of them warped. That was frustrating because it no longer closed tightly.
I was also worried that the drawer bottoms might absorb moisture since the storage room in the basement was relatively humid. So, I set up a dehumidifier — that really helped, and the panels stayed in good condition.
If you store the parts standing, I would also recommend supporting them with sturdy boards or something similar to prevent them from falling over.
Don’t worry, this happens to many people, but with a few small precautions, it works out well.
Eleanor
17 May 2021 13:29
I would always store fronts horizontally. Cabinets are best stored assembled or standing, but secured. Avoid moisture, otherwise they will swell. It is important not to place heavy objects on the parts.
NUPIN
18 May 2021 08:15
Hey Gapofra, great topic! I was also unsure at first, but after I stored my Metod parts properly, I had no problems!
One tip from me: see if you can place the fronts on something soft (e.g., blankets) to avoid scratches. And definitely don’t lean them against a wall, as they can easily warp. The drawer bottoms also worked great for me when stored flat.
You can do it—don’t stress! The path to the perfect kitchen takes some effort, but it’s totally worth it 😉.
koduga
18 May 2021 09:42
NUPIN schrieb:
check if you can place the fronts on something soft (e.g., blankets)
That’s really great advice!
I also protected the corners of the fronts with foam or a few old towels. Especially when stacking them, the edges can get damaged quite quickly.
Eleanor schrieb:
Avoid moisture, or they will swell
I fully agree with this point. Sometimes it’s underestimated, but even typical basement humidity can be problematic. I would also recommend not storing them for too long, if possible.
