ᐅ How do I properly secure BILLY shelves on uneven floors?
Created on: 23 May 2023 10:12
Ronteo4
I have several BILLY bookcases from IKEA at home that I would like to securely fix on a relatively uneven floor. The problem is that the parquet flooring in one room has slight slopes and irregularities, which causes the shelves to wobble slightly or not stand properly under load.
My specific question is: How can I properly secure BILLY bookcases on uneven floors so that they stand stable and safe without compromising their load capacity or overall appearance? What suitable materials, methods, or accessories are available to compensate for unevenness and ensure the stability of the shelves?
Perhaps someone has practical experience with special leveling plates, shims, or alternative safety systems that are also aesthetically acceptable.
Thank you in advance for your tips and ideas!
faso31
24 May 2023 16:21
nedagla schrieb:
And besides: If you fix the shelves to the wall, you can be sure that hardly anything will wobble.
I would like to take a closer look at this point. While wall mounting is important for safety, it does not eliminate problems caused by an uneven floor surface. If the shelf does not stand firmly on the floor, mechanical stresses can develop over time, putting strain on screws and anchors in the masonry, which in the worst case can lead to cracks or loose fittings.
Therefore, stabilization at the base should be taken at least as seriously as wall fixing. Only a combination of both ensures long-term stability.
Ronteo4 schrieb:
Is there any experience with how effective the clamping between shelf and wall can be with uneven walls?
The issue of uneven walls adds further complexity. Rigid pressing is not effective here. Flexible spacers and adjustable anchors can help to distribute forces more evenly, avoiding concentrated stresses on the wall or the shelf.
Jesus9
25 May 2023 08:52
I can only confirm that safety is especially important with BILLY shelves, particularly if there are children in the household.
Nakar33 schrieb:
Wall fixing: BILLY shelves come with mounting hardware to secure them to the wall. This provides a significant safety advantage
This is not just a nice extra, but absolutely necessary if your floor is uneven or your shelf wobbles a bit. You feel much safer when the shelf cannot simply tip over.
Personally, I have also tried to level the shelf using simple wedges on the floor. That does work, but you should regularly check whether the wedges are still in place, especially if the shelves are frequently loaded and occasionally moved.
It is also important not to rely solely on the wall fixings to hold the shelf, but always combine both methods. That gives peace of mind and is the best solution for durability and safety.
Good luck with your project!
U
uslis47
25 May 2023 12:03
Ronteo4 schrieb:
Also, I’m open to tips on how to minimize the visual impact of the necessary adjustments since the shelf is very much in the line of sight.
visually unobtrusive solutions are definitely possible. Here are some practical tips:
- Use furniture feet or wedges in matching colors, which are available, for example, in wood finishes or neutral white/beige tones.
- For wall spacers, flat plastic or felt pads work well and can often be placed almost invisibly behind the shelf.
- If you cut small wooden wedges yourself, you can sand them thinly and paint them in a matching color.
- Another option is to cover the floor under the shelf with a thin, neutral-colored plastic mat that hides unevenness and protects the surface at the same time.
- Adjustable feet sometimes come with decorative covers that act like small trim pieces.
This way, technical and aesthetic requirements can be well combined.
