ᐅ How do I properly secure BILLY shelves on uneven floors?
Created on: 23 May 2023 10:12
Ronteo4
Ronteo4
23 May 2023 10:12
I have several BILLY bookcases from IKEA at home that I would like to securely fix on a relatively uneven floor. The problem is that the parquet flooring in one room has slight slopes and irregularities, which causes the shelves to wobble slightly or not stand properly under load.
My specific question is: How can I properly secure BILLY bookcases on uneven floors so that they stand stable and safe without compromising their load capacity or overall appearance? What suitable materials, methods, or accessories are available to compensate for unevenness and ensure the stability of the shelves?
Perhaps someone has practical experience with special leveling plates, shims, or alternative safety systems that are also aesthetically acceptable.
Thank you in advance for your tips and ideas!
Nakar33
23 May 2023 11:37
Hello Ronteo4,
First of all, thank you for the very clear and precise question, that makes answering much easier!
To securely stabilize BILLY shelves on an uneven floor, it is important to proceed systematically:
1. Floor assessment: Start by using a spirit level or a laser level to determine the degree of unevenness, so you can plan the necessary height adjustments.
2. Shims/spacers: You can buy special plastic shims that are placed under the shelf feet. They come in various thicknesses, allowing for precise compensation of unevenness. I especially recommend adjustable furniture feet, some of which are height-adjustable with a threaded mechanism – this is a very flexible method.
3. Wall anchoring: BILLY shelves come with fixing hardware to secure them to the wall. This provides a significant safety advantage and minimizes wobbling. If the wall itself is uneven, small washers can also be used here for adjustment.
4. Leveling the floor surface: If the unevenness is greater (e.g., over 1–2 cm (0.4–0.8 inches)), you can use floor pads or even a thin wooden board (e.g., plywood) as a base, as long as it fits aesthetically.
5. Rubber mats: Placing non-slip rubber mats under the feet helps prevent slipping.
Now, a question: How severe is the unevenness in your case? Less than 1 cm (0.4 inches) or more? The type of floor (wood, tile, concrete) also influences the most suitable solution.
I hope this helps for now. I’m happy to provide more tips if you share further details.
nedagla
23 May 2023 12:45
Hello Ronteo4 and everyone else,
wow, it’s great that you’re thinking this through carefully before just attaching something! 🙂 Uneven floors can be really frustrating, especially when shelves start to wobble.
From my experience: I recently had a similar issue and simply used small rubber furniture wedges, which are very flexible and even non-slip! I found this extremely practical and it doesn’t look out of place at all.
Also: If you secure the shelves to the wall, you can be sure there will be hardly any wobbling. One more tip: If you have children at home, this kind of fixing is almost mandatory, especially for taller shelves like BILLY.
Keep us updated on what you decide! I’m wishing you luck finding the perfect solution :-)
cassandra
23 May 2023 14:02
To add to the previous explanations, here are some precise facts:
1. Measuring: For exact leveling, a precise leveling instrument or at least a good spirit level with a bubble vial is recommended.
2. Material selection: Plastic shims or wooden wedges are recommended, as they are both stable and permanently elastic.
3. Adjustable furniture feet (also replacement parts for BILLY) offer the highest flexibility for fine height adjustment.
4. Wall mounting: IKEA always recommends securing BILLY shelves to the wall using the included anchors and brackets. This is strongly advised for safety reasons.
5. Aesthetics: To maintain appearance, shims or supports under the feet can be concealed with suitable coloring.
6. Alternative: For very uneven floors, installing a floor filler (feet with larger contact surfaces) can be useful to optimize load distribution.
I recommend systematically starting with measuring, then selecting the appropriate materials, and definitely including wall mounting.
Ronteo4
24 May 2023 09:16
Nakar33 schrieb:
One more question: How large are the uneven spots in your case? Under 1 cm (0.4 inches) or more? The type of floor (wood, tiles, concrete) also affects the suitable solution.
Thanks in advance for the detailed advice!
The unevenness is roughly between 0.5 and 1 cm (0.2 to 0.4 inches), mostly small steps in the solid wood plank flooring. This is an older building, so the floor isn’t perfectly level. The shelves will mainly hold books and will be placed against a wall that is also slightly uneven (not measured, but visually a bit tilted).
I will look into adjustable furniture feet, that sounds very practical. Are there any experiences on how well clamping between shelf and wall works with uneven walls? Or would an additional spacer be more advisable?
Also, I’m open to tips on how to minimize the visual impact of any necessary adjustments since the shelf will be very noticeable.
Siflo
24 May 2023 11:47
Ronteo4 schrieb:
Are there any experiences regarding how well the clamping between the shelf and the wall works on uneven walls? Or is an additional spacer more advisable?
A very relevant question in terms of safety.
In general, the standard clamping is sufficient for regular walls. However, with uneven walls, it is important to ensure that the shelf fits securely against the surface – this is usually achieved by using washers or wooden strips as spacers.
Thin strips help create a larger contact area, distributing the pressure more evenly. Plastic spacers can also help prevent pressure marks on the wall.
For easier installation, some users also recommend flexible wall anchor kits that can adjust to irregular gaps.
My advice: In addition to the included plugs, use small plastic wedges or cards as spacers to ensure a secure fit even on uneven walls.
