ᐅ How do I properly replace Malm dresser drawer handles?
Created on: 23 Dec 2022 18:07
Eneasan
Eneasan
23 Dec 2022 18:07
So far, I have never replaced the handles on my IKEA Malm dresser, but I would like to do that now because I no longer like the current ones. I have read several reviews, but I am uncertain about one point: How can I properly replace the Malm drawer handles without damaging the drawers or the wood?
Specifically: What tools should I ideally use, how should I proceed to carefully unscrew the handles, and are there any special considerations when installing new handles, especially since Malm drawers usually have through bolts?
I am also interested to know if the same screw sizes need to be used for other handles or if there is some flexibility.
I look forward to your advice on how to do this as professionally and carefully as possible.
Domau0
23 Dec 2022 19:42
Hello Eneasan,
first of all, a few important details upfront. Replacing the Malm drawer handles properly does require some preparation and care, as the material – usually particleboard with a melamine coating – is prone to damage if screws are overtightened or the wrong tools are used.
Here’s the procedure:
1. Tools: It’s best to use a small Phillips screwdriver for the original screws. If the handle is firmly attached, a screwdriver with an ergonomic grip can help give you better control.
2. Removing the old handles: Open the drawer and hold it steady (preferably with one hand) while slowly unscrewing the screws from the inside of the drawer. It’s important not to pull on the handle at the same time to avoid damaging the outer surface.
3. Screws and measurements: Malm handles are usually fixed with M4 screws, typically 30mm (1.2 inches) long. When buying new handles, make sure the screw length matches to prevent the screws from being too short to hold the handle properly, or too long so they don’t damage the drawer.
4. Installing the new handles: Insert the screws from the inside through the designated holes, position the handle, and tighten the screws carefully but not too tightly, generally about 1 to 1.5 turns, to avoid shredding the wood.
What I’d like to know is whether you plan to use identical handles or completely different ones in terms of shape and mounting? Some handle models might require a different screw length or even washers.
Hope this helps for now! Feel free to get in touch if you have any questions about screw sizes or the material properties of your dresser.
BOLUKEO
23 Dec 2022 21:16
Best: Use a screwdriver that matches the screw head, remove the screws from the inside, and take off the handle. Attach the new handles, insert the screws again, and tighten them carefully. Make sure the screws are neither too long nor too short, otherwise it will jam or not hold properly.
Domau0
24 Dec 2022 08:50
BOLUKEO schrieb:
Make sure the screws are neither too long nor too short; otherwise, they might jam or not hold properly.
In my opinion, this is often the main issue!
One more detail about screw length: If the screws are too short, you’ll be able to attach the handle to the drawer, but the grip will be weak, resulting in loose handles. If they are too long, they can hit the inside back of the drawer, which affects functionality.
I would also recommend checking the screws before installation if the measurements are a bit unclear—preferably using a caliper or ruler. Additionally, if the new handles require drilling slightly to make new holes, work carefully to avoid chipping.
One question: How old is your dresser approximately, and has it ever been modified regarding drawers or handles? This might influence your choice of screws.
Best regards!
