ᐅ How do I properly replace an Ikea Metod cabinet shelf?
Created on: 9 Jun 2023 08:47
kumoja
kumoja
9 Jun 2023 08:47
Hello everyone, I have an Ikea Metod kitchen cabinet and I would like to replace the shelf because it is damaged. I am wondering how to properly replace the Ikea Metod shelf without damaging the cabinet frame or compromising the stability of the cabinet. It is especially important to me whether I need to remove the entire cabinet and how to best take out and secure the shelves. Are there any specific details or tips for this model that I should be aware of? Thanks in advance for your help!
Jeffon
9 Jun 2023 09:12
In general, replacing the shelf in IKEA Metod kitchen cabinets is relatively straightforward if you follow the correct steps. First, it is important to empty the cabinet and, if necessary, remove the door to ensure unrestricted access while working.
The shelves are usually mounted on dowels and inserted into drilled holes; they are therefore slotted in rather than screwed. To remove the old shelf, carefully lift and pull it out without applying pressure from behind onto the carcass, as it is made of particleboard and is sensitive.
If special brackets (such as metal angles or plastic connectors) are installed, they are usually removable – in this case, remove the screws. When inserting the new shelf, make sure it is positioned correctly so that it sits flush without gaps. Important: avoid applying excessive pressure to the side panels to prevent deformation.
Summary: Use a screwdriver, work carefully, completely empty the old shelf, remove the door, then pull out the shelf and insert the new one.
Marlenepa
9 Jun 2023 10:34
Hello kumoja, I completely understand your question! Replacing a Metod cabinet shelf may sound simple, but it can have its tricky points. I recommend being very careful not to damage the brackets and to avoid using force.
Here are my tips for the process:
- First, empty the cabinet completely – this gives you space and helps prevent any damage.
- Remove the doors, as narrow openings make handling more difficult.
- Check how the shelf is mounted: some shelves rest only on plastic or metal brackets, while others are fixed in side holes with wooden dowels.
- To remove the shelf, gently pry it upwards, preferably using a flat, sturdy levering tool.
- Insert the new shelf and carefully place it onto the brackets.
- Make sure the shelf is level and flush with the cabinet walls.
One more note: cracked or damaged shelf pieces are frustrating, but the cause is often overload or moisture. So if load-bearing capacity is important, you should also check the brackets.
I hope this helps! If you have any more questions, feel free to ask.
bapar
9 Jun 2023 15:08
Jeffon schrieb:
The shelves are usually mounted on dowels inserted into pre-drilled holes; they are slotted, not screwed in.
That is correct, and I would like to go into more detail here, as the Metod series uses special mounting points that you should be aware of to avoid mistakes.
The carcass is made of coated particleboard with pre-drilled holes, into which dowels and support brackets are inserted from the sides.
When removing the shelf:
- Avoid applying too much lateral pressure, as the holes can easily tear out.
- If the shelf seems glued or stuck, gently use a lever (e.g., a plastic spatula) under the shelf at several points to create even leverage.
- Removing the doors is not strictly necessary but makes the work much easier.
When inserting the new shelf:
- First, check all dowels and brackets – damaged ones can be replaced individually or reinstalled using standard hardware from a hardware store.
- Position the shelf in the middle, then press down gently until it is fully seated.
- Some models have additional guide rails on the back wall that also need to be taken into account.
Have you already removed the shelf, or are you about to do so? It would also be helpful to know how old your cabinet is and whether you are using the original material or a replacement board.
kumoja
10 Jun 2023 07:23
Marlenepa schrieb:
Check how the shelf is installed: some shelves simply rest on plastic or metal brackets, while others are secured with wooden dowels through holes in the side panels.
This is an important point. My cupboard shelf is a melamine-coated particle board that fits into holes in the side panels, which are supported by plastic or metal holders. I will remove the doors before taking out the shelf to have better access.
bapar schrieb:
Have you already removed the shelf, or are you just about to? It would also be helpful to know how old your cupboard is and whether you’re using the original material or a replacement panel.
The cupboard is about 5 years old, and the shelf is original. I have obtained an equivalent replacement shelf, also from Ikea. I have not tried to remove the shelf yet, as I was unsure how to proceed without damaging the cabinet body.
I will attempt to remove the doors tonight and then carefully detach the shelf—making sure not to use force and, if there is resistance, to use the method with a plastic spatula. If I encounter any problems, I will report back.
