Burningfog5 May 2025 22:00Hello,
I built a closed staircase myself. For the risers, I used simple 19mm (3/4 inch) three-layer boards from the hardware store. I filled, sanded, and painted them white. It looked pretty good when I installed it—nice, even, smooth painted surface. I didn’t want any wood grain or texture showing through.
Now, however, you can still see the grain slightly in some spots, and in others, the paint has cracked along the grain.
What did I do wrong? How is this usually done? Is there still a chance to fix the risers while they are installed?
This issue is quite common with three-layer panels or wood-based materials with a pronounced grain. Even if you have filled and sanded the surface, the wood continues to move. Moisture, temperature changes, and mechanical stress cause the fibers to raise slightly again or the paint to crack due to tension. Especially with basic panels from hardware stores, the surface often isn’t ideal for achieving a perfectly smooth paint finish.
Usually, this can still be fixed afterwards, but it requires some patience. First, smooth out cracks and visible texture with fine sandpaper, then apply a high-quality primer or sealer that helps to seal the wood and cushions stress a bit. Afterwards, sand again and apply a high-quality topcoat, preferably with an intermediate sanding step. When the panels are already installed, the process is a bit more demanding, for example careful masking around the edges and using a small roller or fine brush for corners, but it’s definitely doable.
If you want to be on the safe side, choose a polyurethane (PU) or acrylic paint with high elasticity, which remains stable even with slight movement in the material.
Kind regards
Kind regards
Burningfog7 May 2025 16:57Thanks a lot for the response and the tips. It will probably become a winter project sometime in the 2030s 😉.
Maybe I’ll prime the backside early with a moisture barrier sealer, so less moisture gets into the board and it expands and contracts less.
