ᐅ How do I properly clean Ikea Pax wood surfaces?
Created on: 9 Jan 2023 08:37
EZELMI
EZELMI
9 Jan 2023 08:37
I recently purchased an Ikea Pax wardrobe with wood-effect oak surfaces and want to make sure I clean the wood surfaces correctly and sustainably, without damaging them or affecting the protective layer of the material.
My question to the experts here: What are the best methods and products to properly clean Ikea Pax wood surfaces?
I am especially interested in which cleaning agents are suitable, whether aggressive cleaners should be avoided, and the best approach for common stains like fingerprints, dust, grease marks, or possible water spots.
Tips on care products that protect or refresh the surface would also be helpful.
Thank you in advance!
Lorukeo
9 Jan 2023 10:56
As a general recommendation for Ikea Pax wooden surfaces:
- Use a soft, slightly damp microfiber cloth to remove dust and light dirt.
- Avoid harsh or abrasive cleaning agents such as ammonia, alcohol, or bleach, as these can damage the surface.
- For stubborn stains, a few drops of mild dish soap in warm water work well. Moisten the cloth, wipe the surface, then follow with a clean, damp cloth and dry thoroughly.
- Do not leave any wet spots on the surface after cleaning, as wood-based materials can swell.
- Using special wood care oils or waxes is not necessary, since Ikea typically seals the surfaces with melamine resin.
In case of doubt, Ikea itself advises avoiding aggressive chemicals and cleaning carefully to preserve appearance and durability.
naujon
10 Jan 2023 14:23
Hello EZELMI,
I would like to add a brief cleaning tutorial for Ikea Pax wooden surfaces:
1. Preparation: First, remove any coarse dust or dirt from the surface—ideally with a dry microfiber cloth or a soft hand broom.
2. Cleaning solution: For damp cleaning, prepare a solution of lukewarm water and a drop of mild dish soap.
3. Application: Lightly dampen the microfiber cloth—do not soak—and wipe in the direction of the wood grain. Avoid pressing or scrubbing to prevent damaging the surface.
4. Rinse: Then wipe thoroughly with a second damp cloth (water only) to remove any soap residues.
5. Drying: Be sure to wipe dry with a dry cloth to avoid leaving moisture on the wood surface. Damp spots can cause swelling or discoloration.
Common mistakes include leaving too much water on the surface or using aggressive cleaning agents.
Summary: mild dish soap + microfiber cloth + thorough drying = best care.
If there are stains like grease or adhesive residues, gently treat them with a cotton swab soaked in alcohol, then quickly wipe dry to prevent color changes.
I hope this helps!
Ankeli
11 Jan 2023 09:05
That basically covers it. Avoid abrasive cleaners and standing water.
Lorukeo
12 Jan 2023 22:46
An important note: The surfaces in the Ikea Pax system are usually melamine-coated or laminated, not untreated wood. This means they are easy to maintain but sensitive to excessive moisture and harsh cleaning agents.
- As an additional recommendation: If you want to refresh the surfaces, special furniture care sprays designed for wood coatings are suitable to maintain shine and protection.
- Always test new products in small, inconspicuous areas before applying them on larger surfaces.
- Fingerprints are best removed with a damp cloth and, if needed, a little dish soap. Afterwards, wipe dry to avoid water marks and dull spots.
- Never use sharp tools or abrasive sponges on stubborn stains to prevent damaging the surface.
These tips will help preserve the appearance and function of your Ikea Pax wood surfaces for many years.
