ᐅ How do I properly clean Ikea PAX wardrobes with different surface finishes?
Created on: 15 May 2024 08:37
KeodursunK
Keodursun15 May 2024 08:37Hello everyone,
I own several Ikea PAX wardrobes with different finishes, including matte lacquered fronts, high-gloss, and a version with foil coating. Since I want to be careful not to damage the wardrobes, I’d like to ask the community:
How do you clean your Ikea PAX wardrobes with these various finishes most effectively? Are there any specific cleaning products or methods you would recommend for each type of material? I’m especially interested in how to deal with stubborn stains or fingerprints without damaging the surface or causing it to become dull.
Tips for regular maintenance would also be great, to keep the wardrobe systems looking good for a long time. Thanks in advance!
Hello @Keodursun,
I’m happy to provide you with a clear guide on how to effectively and gently clean your Ikea PAX cabinet surfaces. It’s important to choose the right method depending on the surface to avoid any damage.
- Matte painted fronts:
- Use a soft, damp microfiber cloth.
- If necessary, use a mild dish soap solution (1–2 drops per 1 liter (34 fl oz) of water).
- Avoid harsh cleaners, as they can dull the finish.
- For stubborn stains, gently treat with a slightly moistened sponge, but do not rub.
- High-gloss fronts:
- Dry polish with a special microfiber cloth designed for glass or high-gloss surfaces.
- For cleaning, use lukewarm water with a drop of neutral cleaner.
- Do not use abrasive sponges or cleaning pastes.
- Fingerprints can be removed with glass cleaner, but use sparingly.
- Foil-coated surfaces:
- Best cleaned with a soft cloth and lukewarm water.
- Avoid aggressive chemicals and alcohol-based products.
- Refrain from rough mechanical cleaning to prevent scratching the protective foil.
Summary: Always use mild agents, soft cloths, and never scrub intensively. Regular wiping with a dry microfiber cloth prevents dust and fingerprints.
If you have questions about specific types of stains, feel free to ask.
LOGEMIN schrieb:
A soft cloth with lukewarm water works best.This is a good starting point. Additionally, it is important to consider that drying plays a key role with high-gloss surfaces. Moisture that is not completely removed can cause water spots.
Neutral cleaning agents without solvents or abrasive ingredients are preferable. Aggressive substances can especially affect adhesion or coloration on laminated surfaces.
When removing stains, it is advisable to proceed gently without applying pressure to avoid mechanical damage. For PAX furniture made of wood or veneer, a higher-quality, gentle treatment is generally important, as the surface is sensitive to excess moisture.
For maintenance, I recommend wiping surfaces regularly with a dry cloth and removing heavier dirt promptly to prevent long-term damage.
Keodursun schrieb:
How do you clean your Ikea PAX with its different surface types most effectively?I usually use a damp microfiber cloth for all surfaces. For stains, a little mild dish soap mixed with water. Avoid abrasive cleaners or alcohol, as these can damage all the finish types.
I would like to share a few additional tips based on experience with several PAX combinations:
- For high-gloss fronts, avoid using ammonia-based glass cleaners, as they can dull the surface over time. It’s better to use cleaners specifically recommended for plastics that do not contain aggressive solvents.
- When cleaning foil-coated surfaces, make sure to keep them sufficiently dry. Moisture seeping into the edges can cause the foil to come loose.
- Matte painted doors do not tolerate alkaline cleaners (e.g., all-purpose cleaners), as these can damage the paint and leave matte spots.
- Fingerprints can be effectively removed with a lightly dampened microfiber cloth without applying pressure.
- In general, when cleaning, it helps to wipe small areas in a straight motion towards the front instead of circular movements to avoid streaks on high-gloss surfaces.
To summarize, here is a brief checklist:
- Microfiber cloth + lukewarm water (basic cleaning)
- Mild dish soap only if necessary
- No abrasive cleaners or alcohol
- Immediate thorough drying
- Avoidance of aggressive or alkaline cleaners
If anyone has specific stains (e.g., marker or adhesive residues), I can also suggest more targeted methods.
