ᐅ How do I properly clean glossy Ikea Metod cabinet fronts?
Created on: 17 Apr 2015 08:12
Don64
I recently installed glossy IKEA Metod cabinet fronts in my kitchen and am now looking for the best cleaning method that preserves the high-gloss finish without damaging the surface.
I am especially interested in tips on the right cleaning solution, appropriate tools, and how to avoid micro-scratches.
Can anyone tell me if special cleaning products are necessary or if common household remedies are sufficient?
I would appreciate any helpful experiences or recommendations!
Don64
17 Apr 2015 11:02
Thanks for the previous tips!
Is it actually a problem to spray a glass cleaner on the fronts after cleaning and then wipe them down with a soft cloth? I’m asking out of concern because some glass cleaners contain ammonia or alcohol.
Would that damage the finish, or is it safe?
I’m also interested in how often the fronts should ideally be cleaned assuming normal kitchen use.
V
vinli
17 Apr 2015 11:45
Don64 schrieb:
Is it a problem to spray glass cleaner on the fronts after cleaning and then wipe with a soft cloth?
Glass cleaners containing ammonia or alcohol are not strictly prohibited, but frequent use can damage or dull the surface.
I recommend using such cleaners only occasionally and sparingly, and always performing a compatibility test on an inconspicuous spot. For regular cleaning, mild soapy water is more suitable.
This depends on how often they are used, but in a typical kitchen, cleaning about 1-2 times per week should be sufficient to effectively remove grease and dust.
JAMESONB41
17 Apr 2015 12:22
No glass cleaner with ammonia.
Mild dish soap, warm water, soft cloth.
Use glass cleaner only for heavy dirt, but sparingly.
Declan55
17 Apr 2015 13:05
Great topic! At first, I was really concerned about the large surfaces and the high-gloss finish, but using a microfiber cloth and mild cleaning worked really well!
It’s really satisfying when the fronts shine beautifully and are clean 😊
Also, a tip: fingerprints can usually be easily buffed out if you wipe them off quickly!
KINMIN4
18 Apr 2015 07:34
Wipe off fingerprints with a dry microfiber cloth.
Do not use harsh cleaners.
Dish soap with water is usually sufficient.
Henry
18 Apr 2015 09:18
Declan55 schrieb:
Fingerprints can usually be polished out easily if you wipe them off quickly!
Exactly, that’s my most common mistake: not wiping immediately, which lets the oil settle.
That’s why I use a small spray bottle with water, spray lightly, wait a moment, and then wipe off right away with a soft cloth.
