Hello everyone, I recently bought some furniture pieces from the Ikea Brimnes series, which are especially known for their wooden components. Since I value long-lasting appearance and durability, I’m wondering: how should the wooden parts of this furniture be properly maintained?
I’ve read that the surfaces of Ikea furniture need to be treated differently depending on their finish. The Brimnes series mainly consists of particleboard with laminate surfaces and some MDF parts, and I’m unsure if I need to use specific cleaning products or care methods to avoid scratches, discoloration, or surface damage.
Could anyone share tips on the best way to clean the wooden parts, which cleaning or care products are suitable, and what should definitely be avoided? Are there any recommendations for long-term maintenance to prevent the material from drying out or becoming brittle?
I’m looking forward to your professional experiences and advice!
For the maintenance of the wooden parts of the Ikea Brimnes series, the surface is generally made of foil-coated particleboard or MDF, which is easy to clean but sensitive to harsh cleaning agents and excessive moisture.
- Preferably use a slightly dampened, soft cloth for cleaning.
- Avoid aggressive cleaners, solvents, or abrasives, as these can damage the foil coating.
- For tougher stains, pH-neutral cleaning agents suitable for laminate or plastic surfaces are recommended.
- After cleaning, the surface should be wiped with a dry cloth to prevent moisture residue.
For long-term care, regular wiping is usually sufficient for foil-coated surfaces. Care products that "nourish" or oil wood are not suitable for Brimnes wood surfaces, as they can damage the foil or leave greasy residues.
In short: gentle cleaning, no standing water, no oil-based care products.
My advice for handling Ikea Brimnes wood panels is based on the fact that these are foil-coated surfaces, not real wood finishes.
1. Regular cleaning:
- Remove dust with a dry microfiber cloth.
- Clean light dirt with a slightly damp microfiber cloth.
2. Stubborn stains:
- For tough stains, you can dissolve a mild dish detergent in water and gently wipe the spot.
- Avoid abrasive sponges, as they can scratch the foil.
3. Mistakes to avoid:
- Do not use solvents (e.g., acetone, turpentine).
- Avoid polishes or waxes, as foil surfaces do not respond well to these.
- Do not use large amounts of water to prevent moisture from seeping into the edges.
4. Long-term care:
- The foil does not require special maintenance, but strong heat or direct sunlight can cause the surface to fade over time.
- If possible, do not place the furniture directly next to a window.
In summary: simple, regular wiping with a lightly damp cloth followed by immediate drying is ideal.
2. Stubborn stains:
4. Long-term care:
I would like to add an aspect that is often overlooked: the edges and joints of the Brimnes furniture are particularly vulnerable to moisture damage.
Therefore, it is important not only to clean the surfaces carefully but also to keep the edges and seams dry and clean. These areas can swell or detach if exposed to excessive moisture.
Additionally, the use of self-adhesive protective films on heavily used surfaces should be chosen with caution, as some films can damage the surface.
In conclusion: gentle care protects not only the appearance but also the durability.
I’m happy to agree with this and would like to add a little tip with a wink:
- Avoid scrubbing when cleaning, as this causes more scratches than shine!
- A soft cloth and some warm water plus mild soap are like the VIP area for Brimnes wooden parts.
Sometimes it’s enough to remove coffee or water stains right away, otherwise it can be frustrating.
A little tip: If the surface looks dull, often a dry, soft cloth is enough to restore some glow. No miracle wax or anything like that – the laminate doesn’t appreciate it 😉
