ᐅ How do I properly install the shelves of the Ikea BRIMNES unit?
Created on: 2 Aug 2020 19:27
fuglaHello everyone, I am currently about to install the Ikea Brimnes shelves and wanted to ask if anyone here has detailed experience or tips on how to properly and securely mount the individual shelves?
It is especially important to me that the shelves are level and that the fixing holds long-term, as I use the shelves for books and some heavier items. Which screws or wall plugs are recommended, and what is the best way to avoid damaging the panels during installation?
A step-by-step guide or advice on common mistakes would be greatly appreciated. Thanks in advance!
I completely understand how challenging it can be to correctly install the BRIMNES shelves, especially when aiming for stability and precise alignment.
I had the exact same experience during my first assembly. The key is to take your time when screwing them in and to regularly check the angles, for example, with a small spirit level. For me, it helped to carefully pre-drill the holes first to avoid cracking the panels.
If you like, I can share more detailed steps on how I approached it or discuss any potential issues with you.
fugla schrieb:
It’s particularly important to me that the shelves sit level and the fixings hold securely over time
To ensure the assembly process of the Ikea BRIMNES shelves is precise and consistently successful, I recommend the following approach:
- First, unpack all individual components and check for completeness and any damage. It is essential to have all screws, wall plugs, and connectors listed in the instructions.
- For mounting the shelves themselves, it is advisable to use the supplied plastic wall plugs if you are attaching them to a wall. The drill holes for the plugs should match the exact depth and diameter of the plugs; using a drill stop or marking the drill bit can help with this.
- When inserting the shelves, make sure to position the metal brackets or holders so that they sit flush with the underside of the shelf structure.
- A common issue is that the BRIMNES units can be sensitive to excessive torque. Therefore, tighten the screws with controlled torque—a cordless drill with adjustable torque settings is ideal.
- Regularly check with a spirit level both front-to-back and side-to-side to avoid any misalignment, which could otherwise cause stress marks on the edges.
- It is best to use the shorter screws specified in the instructions. Screws that are too long may cause the shelves to split.
It would be interesting to know whether you are securing the shelves to the wall or using them as a freestanding unit. This significantly affects the type of fixing required. What is your exact setup?
I am happy to provide a brief assembly overview that can help you safely and effectively install your BRIMNES shelves.
- Step 1: Preparation
Sort all parts and screws, and read the instructions carefully. Pay attention to which screws are intended for the shelves. There are often different sizes, and you should avoid using the wrong ones.
- Step 2: Pre-drilling
If you are not just hanging the shelves but fastening them directly with screws, it is recommended to pre-drill the holes. This minimizes the risk of splitting the material.
- Step 3: Alignment
Place the shelf on the designated supports or slots and check with a spirit level that it is positioned evenly.
- Step 4: Gradually tighten the screws
First, screw them in lightly and check the alignment again. Then tighten evenly without overtightening to avoid damaging the material.
- Step 5: Fix to the wall if possible
To increase the stability of the shelves, use the supplied wall fasteners. Make sure they are properly anchored in the wall, depending on the wall type (e.g., anchors for concrete, special cavity anchors for drywall).
Common mistakes I have noticed are:
- Screws being tightened too tightly or too loosely
- Not aligning the shelves beforehand
- Neglecting the wall fasteners, which significantly reduces stability
I hope this brief guide is helpful. If you have specific questions about tools or screw sizes, feel free to ask.
- Step 3: Alignment
