ᐅ How do I properly and securely install IKEA Metod cabinet handles?
Created on: 8 Jan 2021 07:42
elbasand57
Hello everyone, I am about to install the handles on my Ikea Metod kitchen cabinets and want to make sure the mounting is done correctly and securely. My main question is: How do I install Ikea Metod cabinet handles so that they hold firmly over time and don’t become loose or damage the mounting when pulling or pushing? I have the impression that Ikea often uses screws that are relatively short or that the material isn’t very sturdy. Are there any special tips or recommended methods to secure the handles more reliably? For example, do you need larger washers or additional anchors in the drill holes? And what about tightening the screws so that the material is not damaged but still provides enough grip? I would be very grateful for any helpful advice or experiences.
O
onron
9 Jan 2021 13:27
LIELCHEN schrieb:
Let’s be honest, the industry knows that a strong fixing requires more effort, but the customer is expected to make improvements themselves.
That is a valid point, but it should not be forgotten that Ikea fundamentally follows a very cost-conscious approach. Compromises in terms of materials and manufacturing are therefore unavoidable.
Still, it makes sense to improve stability with simple measures like using screws of the right length and washers. This should be considered the next step, as Ikea fittings are generally adequately sized for normal use.
For higher-quality applications or special stresses, it is indeed advisable to retrofit with professional screws or anchors.
rebufar
10 Jan 2021 15:02
LIELCHEN schrieb:
Would you install such half-finished parts in a kitchen with a professional standard just like that?
I find it interesting that you raise this issue to a fundamental level. For many, Ikea kitchens are entry-level or interim solutions that don’t have to compete with the standards of solid wood kitchens.
The handles are usually a weak point, and that’s exactly where creativity is needed during installation. I don’t see this as a disadvantage, but rather as part of the challenge that comes with the system. For some, this might even be considered an elite problem.
Those who aim for lasting perfection should indeed invest in higher-quality fittings and installation techniques.
DAMALO
11 Jan 2021 10:11
onron schrieb:
For higher quality applications or special demands, it is indeed advisable to retrofit with professional screws or anchors.
I can confirm this from my own experience. I have reinforced the Ikea handles in a heavily used kitchen several times by using longer stainless steel screws with suitable washers. This ensures reliable durability even with daily use.
You just need to think one step further and not settle for the prefabricated solution when stability is the priority. A bit of skilled adjustment really helps.
