ᐅ How do I properly and securely attach IKEA Metod baseboards?
Created on: 11 Jan 2023 09:23
Kidapin
Kidapin
11 Jan 2023 09:23
Hello everyone, I am planning to install the kickboards for the IKEA METOD kitchen system in my home and want to secure them properly so that they hold up long-term without loosening or getting damaged. The kickboards are either made of wood or plastic, and IKEA usually only supplies clips or screws. My question is: which installation method provides the best long-term stability and appearance? Is it necessary to fasten the kickboards additionally with screws, or are the clips alone sufficient? What about preparing the subfloor, especially with slightly uneven floors or tiles? Are there any tips for cutting and fitting the kickboards precisely to prevent warping due to temperature changes or moisture? I look forward to detailed experiences and recommendations on the correct and durable installation of the METOD kickboards, not only regarding durability but also care and potential later replacement if needed.
tyson51
11 Jan 2023 10:55
Hello, I have assembled several Metod kitchens and can recommend the following: IKEA’s standard Metod plinths are usually mounted using clips that attach to the underside of the base cabinet. This is how the manufacturer intends it, and in practice, it holds very well as long as the clips are positioned correctly and securely screwed in place.
Important before installation:
- Clean the surface and check if the floor is level.
- If necessary, compensate for unevenness with a thin leveling material or slightly adjust the cabinets themselves.
- Cut the plinths to size with a fine hand saw if needed, and deburr the cut edges.
I advise against attaching the plinths with additional screws or nails, as the material of the plinths is quite delicate and this can lead to warping. The clips provide sufficient stability and allow for easy removal and cleaning if needed. Room temperature and humidity have little effect on the plinths, especially with plastic ones.
reni45
11 Jan 2023 11:32
I recommend using clips approximately every 30-40 cm (12-16 inches) for stable support. Check the floor to ensure the baseboard fits properly everywhere. If necessary, adjust the cabinets. Use additional screws only under very high loads.
Keatondra
11 Jan 2023 16:47
Admittedly, the question is a good one because baseboards are somewhat underestimated – yet they significantly contribute to a cohesive kitchen appearance. The Metod baseboards can actually be easily installed using a clip system; this is standard and is also recommended by IKEA.
However, if you have an uneven floor that causes large gaps, I suggest the following:
- First, level the floor with self-leveling compound or leveling mortar if it is very uneven.
- Alternatively, shim the cabinets underneath and align them precisely.
This also protects the baseboards so they don’t sit crooked or warp.
Additionally, it helps to screw the clips at the correct intervals. I personally used clips every 30 cm (12 inches), which prevents wobbling or sagging.
For cutting: Use a fine blade saw (e.g., a metal saw or small handsaw) and then deburr all edges well to prevent fraying. If you like, I can also give you some tips on the corners, as the Metod baseboards often come with corner connectors.
In general, I find it sensible to carefully and regularly check the clips and their fastening, especially if the kitchen is under stress or shifted.
Regarding temperature and humidity: In normal household kitchens, this is not an issue as long as the baseboards are not exposed to direct and prolonged moisture.
jan10
11 Jan 2023 18:13
Secure the clips firmly, maintain the spacing, check the floor, align the cabinets. Do not screw through the baseboards, as that will break them.
anfeteo
12 Jan 2023 07:51
I would like to provide a brief step-by-step guide on how I install Metod baseboards to ensure a durable and clean result:
1. Preparation
- Thoroughly clean the floor and check for any uneven areas.
- Level the cabinets using a spirit level, and use small wedges or adjustable feet as needed.
2. Cutting
- Cut the baseboards to length with a fine-toothed saw or a precise handsaw.
- Smooth the cut edges with sandpaper to prevent splinters.
3. Clip Installation
- Attach the clips evenly every 30 to 40 cm (12 to 16 inches) along the middle section of the underside of the baseboards.
- Tighten clips firmly but not excessively to avoid damaging the material.
4. Securing to Cabinets
- Fix the clips to the underside of the base cabinets using the supplied screws.
- Ensure there are no gaps and that the baseboard sits flush.
5. Final Check
- Hang the baseboards and check they fit firmly without shifting.
- Adjust the clips or cabinet positioning if necessary.
Common mistakes include using too few clips, incorrect clip placement, or neglecting the floor’s condition. Applying too much force when installing the baseboards can also damage the material. With this method, I have not encountered issues like warping or loosening.
If you have any questions, I am happy to help.
