Hello everyone, I have some Ikea Malm furniture in my home office that I really like, but for some time now I've noticed that the surfaces are warping slightly – especially on the drawer fronts, where you can see slight bulges, and the doors no longer close flush. I have read that the engineered wood and surface finish can be quite sensitive to moisture and temperature fluctuations.
My question: What is the best way to deal with Malm furniture warping? Are there practical, simple measures to reduce or even reverse the warping? Should I use moisture, heat, or just patiently wait for stable climate conditions? Are there any tips for long-term prevention to avoid this happening repeatedly?
I would be very grateful for any experience or even step-by-step instructions on what I can do myself without damaging the furniture. Thanks in advance!
miAlessio23 Sep 2020 20:44Hello Liteo49,
It’s good that you have already narrowed down your problem to some extent – that makes it much easier to provide assistance.
First of all: Warping in Malm furniture (made from particleboard with a melamine resin coating) often occurs due to an imbalance in moisture absorption between the front and back sides of the panels. The laminated surface is not completely water-resistant, and when humidity levels fluctuate, the material contracts or expands unevenly.
Here is a brief guide that I often recommend:
1. Climate control: Maintain a consistently moderate indoor humidity level (around 40-60%). Especially during the heating season, the air is often very dry, which can cause the engineered wood to dry out and shrink.
2. Seal the surfaces: Applying a sealant or special clear coat on the edges (often the weak spots) can help reduce moisture absorption. However, this requires some craftsmanship and careful application, as the original coating can be damaged.
3. Even treatment: Some people have had good results by gently dampening the back side of the panel with a damp cloth (not wet!) to help balance moisture levels. But be careful: too much moisture can permanently damage the furniture.
4. Mechanical correction: If the warping is more severe, targeted adjustment of screws or replacement of damaged parts (e.g., back panels) may help.
5. Long-term prevention: Avoid direct sunlight and rapid temperature changes, as these cause the panels to warp most quickly.
Important: Do not experiment with heat sources (e.g., hairdryers), as these can soften the surface coating or even cause bubbles.
Summary: Keep a stable indoor climate, monitor edges and backsides for moisture, and never apply too much water directly to the furniture. If problems persist, it may be worth replacing the affected parts or seeking professional advice.
If you like, I can provide more detailed instructions on the steps once I have more information from you, such as which parts are particularly affected.
miAlessio schrieb:
Warping in Malm furniture (made from particleboard with melamine resin coating) often occurs due to an imbalance in moisture absorptionAbsolutely correct. I’d like to add a few technical details here because many are not aware: The Malm series uses MDF or particleboard with a melamine foil surface, which is quite durable, but the board itself is hygroscopic (absorbs moisture). The deformation often happens because the front and back absorb different amounts of moisture.
For example, if the backside is less sealed than the front, it will absorb more moisture and expand. This causes the board to bow slightly. Conversely, it can shrink in dry heated air.
A very helpful step is:
- Carefully remove the back panel and check its condition. If it’s warped or damaged, that can affect the stability.
- Check the screws and joints at the corners. Loose screws can promote warping because the board isn’t held firmly anymore.
- For more severe warping, it helps to lay the board on a flat surface and apply some weights – this can reduce the bowing over time.
- Make sure there is no water damage. Malm furniture is not water-resistant, and the boards will swell quickly when wet.
One more tip: If the edges of drawer fronts are warped, you can carefully sand them lightly with fine sandpaper, but this should only be done by experienced DIYers.
What’s also important to me: Is the furniture placed in a room with strong fluctuations in humidity?
Liteo49 schrieb:
Should I work with moisture, heat, or just patiently wait for more stable climatic conditions?My advice: Patience is the most helpful, ideally combined with monitoring the room’s humidity to avoid extreme drying or excessive moisture. Applying moisture evenly should only be done very cautiously.
Liteo49 schrieb:
What is the best way to deal with warping in Malm furniture? Are there practical, simple methods to reduce or even reverse warping?I can fully understand how frustrating it is when you have used furniture for a long time and suddenly face these visual and functional issues.
Something similar happened to me: my Malm chest of drawers developed a slight bowing on the drawer fronts, and I spent a long time deciding whether to replace it or if it was worth trying to repair.
Ultimately, I learned the following:
- Accept that the challenge with MDF/particleboard furniture with foil surfaces is that they are sensitive to the indoor climate – this can be emotionally hard to accept if you think of wood as something permanent.
- If you don’t want to replace the furniture, focus on optimizing the room climate and rule out mechanical causes, such as uneven floors or slamming drawers.
- At home, I ran a humidifier on the lowest setting at night, which at least temporarily relieved the stress in the panels by preventing them from drying out.
- Small deformations can sometimes be corrected by placing a thin damp cloth on the back of the panel and then applying weight, but this doesn’t always work and should be done carefully.
It’s sometimes also a matter of patience and observation. Maybe you can check if the warping gets worse during certain seasons?
And: don’t get discouraged; furniture can be a bit “alive” sometimes – and that’s not a bad thing. 🙂
