ᐅ How can I prevent water stains on Malm furniture?
Created on: 4 Aug 2018 08:17
pranar
pranar
4 Aug 2018 08:17
Hello forum,
I have a problem with water stains on my Malm furniture from IKEA, especially on the nightstands and the desk. The furniture is made of lacquered MDF with a smooth surface, but as soon as I place a glass of water on it without a coaster, unpleasant circular water marks appear.
I would like to know the best way to prevent these water stains without covering the furniture with large surface protectors that would hide its appearance. Ideally, the method should be practical for everyday use, meaning it should require little effort and pose no risk to the surface, such as damage from moisture during cleaning or abrasive products.
What are your tips for avoiding water stains? Are there special care products or home remedies I can use? Or perhaps practical solutions like coasters that work especially well?
I look forward to your advice!
tetan
4 Aug 2018 09:03
Coasters are the simplest and safest solution.
Alternatively, you can use a thin protective film that remains transparent. Usually, more effort does not provide better protection.
tolokau
4 Aug 2018 11:26
Hello pranar,
I would like to organize my response a bit to help you review the best tips systematically:
1. Protection with coasters: As mentioned before, this is the first step. Make sure to use non-slip and absorbent materials, such as felt or silicone.
2. Surface care: Regular cleaning with mild products suitable for lacquered surfaces helps maintain the protective layer.
3. Additional sealing: It is possible to apply special furniture polishes or waxes afterward to create an extra protective film. Make sure these products are compatible with MDF and lacquered surfaces.
4. Home remedies: Some recommend applying a thin layer of furniture wax or beeswax, but be careful—too much can become sticky.
5. Avoiding moisture directly on the surface: Be sure to prevent condensation from glasses or bottles. If necessary, slightly lift the glass or use small plates as placeholders.
Common mistakes: Not wiping up water stains immediately, using overly aggressive cleaning products, or rough sponges.
In summary: The best protection is usually a combination of preventive protective pads, gentle cleaning, and, if needed, an additional care sealant.
I hope this helps you!
botibo
4 Aug 2018 12:18
Hi pranar,
I can only say: coasters are your best friends! 🙂 I personally like to use round felt coasters—they’re almost invisible and work perfectly.
Absolutely right—minimal effort and you stay flexible.
One more tip: If you get a stain that you can’t wipe off immediately, a soft, dry cloth and a bit of furniture polish often help restore the shine.
A little lifehack: simply empty your glass of water in the evening, then there’s nothing to worry about 😉
Cheers! 😊
Ramon4
5 Aug 2018 07:51
Hello pranar,
I can relate to damaged surfaces, as I also have Malm furniture and appreciate its simple design very much. Water stains usually occur from moisture seeping under the finish or from mineral deposits left after evaporation.
My advice:
- Avoid direct contact with water at all costs, so use coasters — absorbent materials are ideal.
- Immediately blot damp spots with a soft, dry cloth after use; do not wipe.
- I have had good results occasionally refreshing the surfaces with a mild furniture polish (not oil!). This helps fill small micro-scratches and preserve the sealing.
If water stains are already present, try gently rubbing with a non-gel toothpaste. Be cautious and test in an inconspicuous area first!
If you have any questions about the exact procedure, I’m happy to help.
blapau
6 Aug 2018 13:34
Hello pranar,
I would like to add a few points from my experience with painted MDF furniture to the existing tips:
- Water stains on Malm often result from mineral deposits left behind when water evaporates. Therefore, wiping up spills promptly is essential.
- Care products containing silicone or wax can protect the surface over time but should be used sparingly and not too frequently to avoid buildup.
- A frequently overlooked factor is the room’s humidity. Higher humidity can promote condensation, which in turn encourages water stains.
- As an alternative to traditional coasters, I recommend small placemats made of clear plastic or glass that can be easily wiped clean as needed without affecting the look.
Ramon4 schrieb:
After use, immediately dab wet spots with a soft, dry cloth—do not wipe.
I fully agree with this, as it prevents scratches.
If you want to clean the surface, use a slightly damp microfiber cloth without aggressive cleaners.
Good luck.
