I recently bought a Malm bed from IKEA and noticed that stress cracks in the furniture are a common issue for some users. I am particularly interested in how to effectively prevent such stress cracks in Malm furniture.
I understand that stress cracks often result from wood or panel movement due to changes in humidity and temperature, but I am specifically looking for practical advice and recommendations that are especially useful for Malm models.
What role do assembly, storage, maintenance, and possibly the surrounding environment play in preventing these cracks? Are there any particular treatment or installation instructions that can be followed easily to ensure the durability of the surface and structure?
I am looking forward to well-informed experiences and tips from the community!
JAMESONB4111 Jan 2018 09:23Mocyrus schrieb:
What role do construction, storage, maintenance, and possibly the surrounding environment play in preventing these cracks?Simply let the furniture acclimate for 24 hours before assembly by storing it in the room where it will eventually be placed.
Also, make sure there is no direct heat source nearby and keep the humidity as stable as possible. This already helps a lot.
JAMESONB41 schrieb:
Simply let the furniture acclimate for 24 hours before assembly by storing it in the room where it will be placed.One of the most important points not to underestimate. Stress cracks often result from moisture fluctuations that cause tension in the wood.
Specifically for MALM furniture, which is usually made of particleboard with a foil surface, it is advisable to handle moisture carefully. This means avoiding placing wet or damp cloths on the surface. The edges are more sensitive and react more strongly to moisture exposure.
Additionally, during assembly, it is crucial to use the supplied screws and connectors carefully, since incorrect screw placement or overtightening can create stress in the boards that may later lead to cracks.
It is also recommended to regularly monitor the room’s humidity level, keeping it between 40 and 60%. Air that is too dry (for example, from heating air in winter) can dry out the material and promote cracking.
tielto schrieb:
Regular monitoring of indoor humidity levels between 40 and 60% is also recommended.I can only confirm this. Last year, with my MALM wardrobe, I had the unpleasant experience of the air becoming very dry during winter. Although I took good care of the furniture, small stress cracks appeared along the edges, which really annoyed me.
What helped me was using a humidifier in the room; it prevented the cracks from worsening, and the furniture now seems more 'stable.'
I also make sure never to expose the furniture to direct sunlight, as this dries out the surface faster and promotes stress cracks. Maybe this helps you too. 😉
If you need more information, I’m happy to assist.
