ᐅ How can I prevent scratches when assembling IKEA Brimnes furniture?
Created on: 21 Sep 2022 19:37
Kirby
Kirby
21 Sep 2022 19:37
Hello everyone, I am planning to assemble an IKEA Brimnes furniture piece soon and am thinking about how to avoid scratches on the surfaces during the process. The Brimnes range is known for its simple design with black and white lacquered finishes, which can easily show small damages.
I generally like to assemble furniture myself, but I have noticed that handling the panels or screwing them together can quickly leave marks, especially on edges or if the screws are not placed precisely.
I am therefore interested in which specific tools, methods, or preparations you would recommend to avoid most surface scratches during assembly. Are there special protective materials, particular screwing techniques, or perhaps handling or laying-down tricks that have proven effective?
I appreciate practical tips that can be applied easily in everyday situations without much extra effort. Thank you in advance!
RETRAVIS
21 Sep 2022 20:11
To avoid scratches when assembling IKEA Brimnes furniture, I recommend the following approach:
- Prepare the work surface carefully: Soft coverings such as blankets or foam mats are ideal, large enough so that the panels do not rest directly on the floor or hard surfaces.
- Choose the right tools: Use a cordless drill with a torque limiter to prevent over-tightening, which can damage the edges.
- Keep protective films on the panels: Panels often come with factory-applied protective films. Remove these only when necessary.
- Handle parts carefully: Work with clean hands when placing and turning the pieces, and keep sharp objects away.
- Prepare screws and fittings: Before assembly, check that all screws are deburred and fit properly to avoid unnecessary friction.
These measures effectively reduce the risk of scratches.
theo63
22 Sep 2022 07:46
RETRAVIS schrieb:
Selecting tools correctly: Use a cordless drill with torque control to avoid over-tightening, which can cause damage to the edges.
This is an important point; however, it is also worth considering whether the use of a cordless drill is truly necessary for Brimnes furniture. Often, these pieces are designed so that a manual screwdriver is sufficient – allowing more careful and controlled torque application. Excessive force from a cordless drill can easily strip screws, leading to scratches or even damaged drill holes.
Additionally, the question arises whether the assembly is taking place in a sufficiently large and flat area. Assembling on a carpet, for example, can provide some protection but also results in instability during screwing, which may cause scratches if the parts slip.
Therefore, I would add: Use a stable, flat, well-padded surface and perform the screwing work as much as possible manually and in a controlled manner to avoid scratches.
KUDAISY
23 Sep 2022 11:02
In addition to the previous posts, I would like to provide a short guide that shows step by step how to effectively prevent scratches when assembling IKEA Brimnes furniture:
- Preparation: Clear the workspace and cover it with soft blankets or yoga mats. Unpack all parts carefully and keep protective films on as long as possible.
- Surface protection: If you don’t have a soft base, place felt pads or fabric pieces under furniture panels at contact points.
- Handling the panels: Always use both hands to hold parts securely and avoid slipping. When placing them on the surface, make sure your hands and the surface are clean.
- Using a screwdriver: Use a screwdriver with a well-fitting bit. If using a cordless drill, set the torque very low and use a low speed.
- Screw positioning: Do not start screwing directly at the edge with the bit pressed firmly; instead, position the bit precisely on the screw head first to avoid slipping and scratches.
- Checking intermediate steps: Assemble the furniture step by step, and in between, do not stack unassembled panels on top of each other to avoid pressure marks.
Summary: Patience and careful handling are key. The right tools, such as a soft base and torque limitation, prevent most damages.
