ᐅ How can I prevent scratches from Malm nylon caster wheels?
Created on: 28 Sep 2020 07:33
Pietsin
Pietsin
28 Sep 2020 07:33
I recently purchased a Malm bed from Ikea equipped with nylon casters. I noticed that when moving it on my parquet floor, small scratches appear. I am now specifically looking for proven methods or sensible precautions to prevent scratches caused by the Malm nylon casters. It is important to me that the floor remains undamaged while the casters continue to roll smoothly.
Are there any special care tips, caster mats, alternative types of casters, or other considerations I should be aware of?
I look forward to your advice and experiences!
Thank you in advance!
Surela
28 Sep 2020 10:11
Hello Pietsin,
Regarding your question "How can I prevent scratches from Malm nylon casters?" I would like to share some detailed advice that has helped me protect sensitive flooring.
Nylon casters are generally suitable for delicate surfaces; however, small particles like sand or dust can still get trapped between the caster and the floor, causing scratches. Therefore, it is important to regularly clean underneath and on the casters to remove any debris.
A proven method is to use protective mats made of materials like PVC or polycarbonate, specially designed for parquet or laminate floors, placed under the furniture casters. These prevent direct friction between the caster and the wood while also distributing the pressure.
If possible with your model, you might also consider replacing the original nylon casters with softer rubber or PU (polyurethane) casters. These tend to have greater elasticity and are gentler on the floor when rolling.
A small tip: pay attention to the size of the casters. Larger casters distribute weight more evenly and reduce point pressure, which helps to minimize scratches.
One more question for you: What exact type of flooring is your Malm bed on, and how often do you move the furniture? That would help in providing the best protection advice.
bulanau
28 Sep 2020 14:27
Hello Pietsin,
here is a structural approach to effectively prevent scratches caused by Malm nylon caster wheels:
1. Preparation: Check that the nylon wheels are clean and free of debris. Even small stones can cause scratches.
2. Protective aids: As mentioned before, felt pads are highly recommended. You can stick these onto the wheels or place small pads directly underneath them.
3. Wheel replacement: If your nylon wheels do not have straps or protective mechanisms, switching to ball-bearing wheels with softer treads (PU – polyurethane) is advisable, as these are less abrasive on sensitive floors.
4. Floor protection: A translucent protective mat made of polycarbonate prevents direct contact between the wheels and the parquet floor.
5. Cleaning: Clean the wheel tracks regularly with a damp cloth to remove dirt and abrasive dust.
Summary: For maximum scratch prevention on parquet flooring, a combination of regular cleaning and use of protective materials is recommended. Feel free to share whether the bed is moved rarely or frequently.
If you like, I can also explain in detail how to properly apply felt pads.
Best regards!
PEDRO40
29 Sep 2020 09:02
bulanau schrieb:
How to properly attach felt pads.
I would like to know that too! I have similar nylon caster wheels, and even though I’m very careful, there are already a few small scratches on my laminate flooring.
Maybe it would also be helpful to hear about others’ experiences with replacement wheels?
I always find it a bit frustrating when you’ve tried everything, yet small damages still appear on the floor. It feels reassuring and calming to know that you’re taking the right precautions.
Hopefully, we can all find a solution that protects the floor without restricting movement too much.
Looking forward to tips on installing felt pads :-)
Surela
30 Sep 2020 16:45
PEDRO40 schrieb:
Maybe it would also be interesting to know what experiences others have had with replacement wheels?
Certainly, when it comes to "How can I prevent scratches on Malm nylon wheels?" replacing the wheels is definitely one possible solution.
In several projects, I have seen that switching to specially designed PU wheels brought a significant improvement. Although these wheels are sometimes a bit more expensive, they pay off due to much better floor protection and easier rolling performance.
Regarding the application of felt pads: these should not just be stuck on, but the surface must be thoroughly dusted and cleaned first, otherwise the adhesive won’t hold properly. For Malm wheels, it is recommended to cut the felt pads precisely to the wheel surface to prevent them from slipping.
Another important point: regularly check the felt pads and replace them when worn, as worn pads can cause more damage by trapping small particles.
One more tip: microfiber cloths combined with a mild cleaning agent work well for cleaning nylon wheels; avoid harsh chemicals at all costs.
I hope this helps and I look forward to your feedback!
