Some time ago, I purchased a few Malm furniture pieces from Ikea, especially dressers and nightstands with the white finish. I have noticed that with daily use, the surface scratches quite quickly, which bothers me because I really like the furniture and want to keep it in good condition for as long as possible.
My question is: How can I prevent my Malm furniture from getting scratched? I would like to know which methods or protective measures you recommend to avoid scratches. For example, are there any special care products, protective films, or should I use coasters and felt pads?
I appreciate any specific experiences or tips that help keep the surface smooth and scratch-free for as long as possible.
Keatondra30 Dec 2021 08:40Hello Maula,
I would like to add to the previous tips that humidity plays a role. Malm furniture made of wood-based materials with a surface finish is sensitive to fluctuations. Too dry air can make the surface more brittle and make small scratches more visible.
A constant indoor humidity of about 40-60% helps keep the furniture in good condition. If needed, use a humidifier during the heating season.
I also recommend gently roughening the furniture once a year with a fine sanding pad (only if the surface is not lacquered but laminated, which can vary with Malm) and then treating it with appropriate furniture care products.
Of course, only do this if you have some experience; otherwise, it’s better to use professional products and seek advice.
Most scratches are caused by dust and sand particles transferred by shoes or objects onto the furniture. Therefore, regular wiping with a microfiber cloth is important.
vinpau schrieb:
Move furniture items slightly instead of pushing them when shifting things on the surface – otherwise scratches can still occur.Thanks for the tip! I hadn’t paid attention to that before.
tra_nina schrieb:
Beeswax is often too thick and can leave unattractive residues on lacquered surfaces.That’s reassuring, as I was considering using beeswax.
I will start with felt pads and get a furniture polish that contains carnauba wax. The idea of using a protective film on heavily used surfaces also sounds very practical.
One more question for everyone: How often should furniture be polished? Is once a quarter enough, or should it be done more often?
