Some time ago, I purchased a few Malm furniture pieces from Ikea, especially dressers and nightstands with the white finish. I have noticed that with daily use, the surface scratches quite quickly, which bothers me because I really like the furniture and want to keep it in good condition for as long as possible.
My question is: How can I prevent my Malm furniture from getting scratched? I would like to know which methods or protective measures you recommend to avoid scratches. For example, are there any special care products, protective films, or should I use coasters and felt pads?
I appreciate any specific experiences or tips that help keep the surface smooth and scratch-free for as long as possible.
Hello Maula,
I had a similar issue with my Malm furniture. It is important to protect the surface from mechanical damage. Scratches are especially noticeable on white, lacquered surfaces.
In addition to using felt pads, cleaning with a soft, damp cloth and a mild detergent is helpful. You should definitely avoid aggressive cleaners or rough sponges, as they can damage the surface.
Many also recommend treating furniture with a thin layer of wax, which provides some protection against fine scratches. Alternatively, you can use self-adhesive transparent protective films, which are often available at hardware stores or online.
Last but not least, when moving or rearranging heavy items, try to lift them carefully to avoid scratches on the base surface.
I hope this helps.
I hope this helps.
Ramon4 schrieb:
Also, many recommend treating furniture with a thin layer of wax, which provides some protection against micro-scratches.Thanks for the tip! Which types of wax are suitable? Do you have any experience with beeswax or other furniture waxes specifically designed for painted surfaces?
DEOLAU schrieb:
Simply always place felt pads under objects and furniture.Do you also use felt pads under decorative items and heavy equipment like bedside lamps or speakers? Or mainly just under chairs and larger furniture pieces?
To prevent scratches on painted furniture surfaces like those on Malm, I can offer some scientifically supported recommendations:
1. Felt pads are highly recommended for the bottoms of furniture to avoid abrasive movements on the floor. They should be regularly checked and replaced to prevent trapping dirt particles that can cause scratches.
2. For the surface itself, specialized furniture waxes or polishes designed for polyurethane or lacquer finishes work well. A suitable product would be a liquid furniture wax containing carnauba wax. Beeswax is often too thick and can leave unattractive residues on painted surfaces.
3. When cleaning the surface, use only soft cloths (microfiber) and mild cleaning agents. Abrasive cleaners or rough sponges will damage the paint layer.
4. Transparent plastic protective films (e.g., acrylic films) can be applied to heavily used areas such as nightstands or dresser tops to prevent direct contact with sharp or heavy objects.
5. Avoid placing heavy or sharp-edged items on the furniture without protection. A coaster made of felt, soft rubber, or cork can help.
Together, these measures can significantly reduce the risk of scratches.
Wow, great tips from tra_nina! 🙂
I once applied a clear protective film to my white Malm dresser myself – and it really works great! The scratches don’t appear anymore, and you can hardly see that there’s anything on it.
Tip: Be sure to thoroughly clean the surface beforehand so no dust particles get trapped underneath!
And very important: when moving something on the furniture surface, slide it carefully instead of dragging – otherwise, you’ll still get scratches.
Glad I could help! :-)
