ᐅ How can I prevent Malm furniture legs from scratching my hardwood floors?
Created on: 13 Nov 2024 09:43
BoHeathI have a fundamental problem and hope to get some practical advice here in the forum: How can I prevent the legs of my Ikea Malm dressers from scratching my hardwood floor when moving them?
The hardwood floor is quite sensitive, and I want to avoid unsightly marks. The furniture is occasionally moved, for example when cleaning or rearranging the room.
So far, I have tried felt pads, but they didn’t last very long; some came loose or shifted.
Are there more durable solutions that have proven effective? I am open to material suggestions, tips on attachment methods, or other technical options. It is important to me that no marks or scratches appear, even if the furniture is pushed occasionally.
Thanks in advance!
Thanks in advance!
BoHeath schrieb:
How can I prevent the legs of my Ikea Malm dressers from scratching my hardwood floor when moving them?Oh, I know that all too well! 😊 Felt pads are a good idea, but as you mentioned, they sometimes don’t last very long. I’ve had great experience with thicker self-adhesive felt pads—they’re a bit more durable and also slide better.
What also helps is regularly checking the felt pads and replacing them before they start to come off. It’s very important that the bottom of the furniture legs is clean and free of grease, otherwise the pads won’t stick properly.
Another option that worked for me is combining felt pads with transparent plastic glides that have a streamlined shape and smoother edges, which don’t catch on the hardwood floor as easily. This way the furniture moves more smoothly without scratching.
A quick tip: If you want to move your furniture with a bit more ease, a handy furniture mover with a felt lining can help. Of course, that doesn’t work equally well for all types of furniture.
Your question hits the nail on the head—contact between parquet flooring and furniture is delicate.
That is important because occasional moving causes wear on the material.
My recommendation is a combination of high-quality felt pads with a thin plastic shim glued underneath to create a durable protective layer.
When attaching, pay attention to the following:
1. Thoroughly clean and degrease the furniture leg surface, for example with alcohol or spirits.
2. Use felt pads with a strong, pressure-resistant special adhesive (e.g., 3M quality).
3. For the plastic underlayer, I recommend a low-friction plastic such as polyethylene, which provides good glide properties.
4. Start applying at the back edge of the furniture leg and press firmly during attachment—this reduces air bubbles that weaken adhesion.
Additionally, I would suggest treating the parquet with a suitable care product that creates a somewhat more robust protective layer (there are special parquet care products available).
One more little tip: For furniture legs with a narrow contact area, it’s worth switching to round felt pads rather than square ones—they distribute the load better and reduce point pressure.
Your furniture legs on the Malm look box-shaped, right? Do you have a stable, flat side surface on the legs or more rounded edges? That could further influence the choice of material.
BoHeath schrieb:
The furniture is sometimes moved, for example when cleaning or rearranging the room.
neoren schrieb:
Have you ever tried special rubber furniture feet? They are non-slip and protect the floor very well.That’s true, but rubber can sometimes stain the floor, especially if it is dirty or ages. Therefore, it’s better to use high-quality types of rubber.
Palenar schrieb:
When attaching, make sure to thoroughly clean and degrease the furniture leg surface, for example with alcohol or spirits.That is a very often underestimated point! If the surface isn’t clean, no felt glide will last long. It’s best to lightly sand with fine sandpaper first, then degrease, and only then stick on the glide.
In general: a little routine makes a big difference. It’s good to always have spare glides ready—so they can be replaced immediately before anything starts to scratch :-)
