ᐅ How can I prevent Malm furniture from getting scratched?
Created on: 1 Apr 2021 08:17
Kody0
I own several Malm furniture pieces from IKEA, specifically dressers and nightstands in white, and unfortunately, I notice unattractive scratches and signs of wear appearing after some time. Despite careful use, the furniture no longer looks good after a while. My question is: What proven methods or products are available to prevent Malm furniture from scratching? I am especially interested in practical protective measures that are effective in everyday use without affecting the appearance or feel. Additionally, I would like to know if certain materials or cleaning routines can improve the durability and condition of the surface.
jeff65
1 Apr 2021 11:27
Sure, I often use products from the brand "Dr. Schutz," especially for laminate and melamine-coated surfaces. They are gentle, caring, and noticeably improve the protective layer. It is important that the product does not contain solvents that could damage the surface.
Dopoki
1 Apr 2021 12:18
In addition to the measures already mentioned, I recommend systematically implementing the following points:
1. Clean only with a slightly damp, soft cloth. Very important: Do not use aggressive cleaning agents or abrasive sponges.
2. Attach felt pads with sufficient thickness (at least 3 mm (1/8 inch)) under heavy items.
3. For additional protection, matte polyurethane protective films designed specifically for furniture can be used. These can be removed without leaving any residue.
4. Reduce mechanical stress, for example, do not place sharp-edged objects directly on surfaces without a protective layer.
This way, surface protection can be significantly improved.
Layla
1 Apr 2021 12:45
Dopoki schrieb:
Reduce mechanical stress, for example, do not place sharp-edged objects directly on surfaces without protection.\
I completely agree with that. I once placed plates or cups without coasters, and as soon as I looked away, small scratches appeared. It happens quickly and is quite frustrating...
Kody0
1 Apr 2021 13:04
Is there a way to repair small scratches yourself or at least improve their appearance? I would like to know if it is worthwhile or if it is better to be very careful, as touch-ups might be more noticeable.
RonJarrett
1 Apr 2021 13:29
Repairing small scratches on melamine surfaces is generally possible, but it only works well for very fine scratches. Special repair markers or wax pastes designed for furniture can help to somewhat conceal the damage. It is important to match the color as closely as possible. However, deep scratches or damaged edges are difficult to repair invisibly. In such cases, replacing the damaged surface, for example with custom-fit laminates, is usually recommended.
BOLUKEO
1 Apr 2021 15:47
A simple, often overlooked tip is to avoid placing heavy or sharp-edged objects directly on surfaces. Just lay a thin layer of felt or plastic underneath. This prevents almost all scratches in everyday use.
