ᐅ How can I prevent IKEA Platsa cabinet doors from squeaking?
Created on: 23 Feb 2021 19:43
pauheraldoP
pauheraldo23 Feb 2021 19:43Hello everyone, I recently assembled an IKEA Platsa cabinet, and although I am generally quite satisfied, the cabinet doors squeak noticeably with every movement, which is quite annoying. I have already checked that the hinges are installed correctly and that the doors are properly aligned, but the squeaking persists. My question is: What can I do to permanently fix this issue? Are there any specific lubricants recommended, or other technical tips to effectively prevent the squeaking without compromising the door mechanism? I would appreciate detailed advice and experiences, as I want to avoid causing any damage and find a solid, clean solution.
pauheraldo schrieb:
Are there any recommended special lubricants or other technical tips to effectively prevent squeaking?Hi! Usually, the squeaking on Platsa doors comes from the hinges. I recommend using a good silicone spray – it’s great because it doesn’t run or attract dust like oil does. Just spray a few bursts onto the moving parts and then gently open and close the door several times to distribute the lubricant. Sometimes a drop of sewing machine oil works as well.
Just be careful not to use too much – it should be smooth, not greasy. If you still hear noises after a few days, check if the hinge screws are tight; loose screws can worsen the fit and cause squeaking.
It might sound simple, but this combination of cleaning, tightening, and light lubrication often works really well.
Hello pauheraldo,
I can fully understand the problem with squeaky cabinet doors – it really affects the overall impression. Here is a brief guide on how to effectively eliminate squeaking on IKEA Platsa cabinet doors:
- Step 1: Remove doors – Carefully lift the door off the hinges to access the mechanism more easily.
- Step 2: Cleaning – Thoroughly clean all contact points with a lint-free cloth and, if needed, some isopropanol to remove dust and old lubricant residues.
- Step 3: Lubrication – Use silicone spray or grease specifically designed for plastic and metal parts. I would avoid mineral oil-based products because they attract dust and can make the problem worse.
- Step 4: Check hinges – Make sure the screws on the hinges are tightly fastened and adjust the doors as necessary so they hang straight and are not under tension.
Finally, rehang the doors and test their movement. If the squeaking continues, it’s worth inspecting the hinges for damage, as small plastic parts sometimes break and cause the noise.
In summary: clean, lubricate properly, check screws, and inspect the mechanism – these are the key steps that should help you. If you want, I can also recommend specific silicone sprays.
REPITAR schrieb:
Use a silicone spray or lubricant specifically designed for plastic and metal parts Exactly, use silicone spray.
Additionally, keep the washers and hinges dry and clean.
Tighten the screws, and that should solve the issue.
