ᐅ How can I prevent damage to the Ikea BRIMNES during assembly?
Created on: 22 Mar 2021 10:07
tanso
tanso
22 Mar 2021 10:07
Hello everyone, I am planning to assemble my new Ikea Brimnes wardrobe soon and want to avoid any damage such as scratches, dents, or missing small parts. Do you have any tips on the best way to approach the assembly to protect the carcass, fronts, and hardware as much as possible? I would also be interested in hearing about experiences on how to spot and prevent minor mistakes during the assembly process in time. Thanks in advance!
TARAON
22 Mar 2021 12:18
Hi tanso! Good question, the BRIMNES piece isn’t small, so things can go wrong easily 🤓. My tip: assemble it on a soft but firm surface, like a large wool blanket or a carpet underlay. This helps prevent scratches on the finish.
- Sort the screws according to the instructions and check that all are included
- Inspect all parts for damage before starting assembly
- Don’t apply too much force when screwing; if something feels stuck, loosen and try again
And don’t worry if something gets stuck—patience is key when putting furniture together!
klo40
22 Mar 2021 14:53
I would like to add a few structured points on how to avoid damage when assembling the Ikea BRIMNES:
1. Prepare your workspace: Find a large, clean area where you can lay out all the parts. Ideally, it should be softly padded to prevent scratches.
2. Have your tools ready: A screwdriver, rubber mallet, and possibly small wedges can help you gently fit parts together.
3. Read the instructions carefully: Each part has a specific assembly order. Don’t rush; take it step by step. Trying things out prematurely can increase the risk of damaging the material.
4. Screw in fasteners loosely at first: Tighten them fully only at the end. This allows for adjustments if parts don’t fit perfectly.
5. Be careful with back panels and fittings: These are often thin and can break easily if too much force is applied.
To identify assembly errors, small pencil marks on critical edges can be helpful to check if everything sits flush. This method is especially useful for the BRIMNES, which has multiple drawers.
Hopefully, these tips help!
elgla
22 Mar 2021 17:39
I can understand well that you want to avoid damaging anything while assembling the BRIMNES; that happens to me quite often too... what a pain! What often helps me is to stay calm and patient and not rush. Sometimes small parts are overlooked or a screw doesn’t fit quite right, which then leads to frustration.
klo40 schrieb:
Insert screws loosely at first: Only tighten them completely at the end. This way, you can still make adjustments if parts don't fit perfectly.
This advice helped me a lot, because before I often thought I had to tighten every screw fully right away. Also, make sure to align the edges carefully when joining parts so they don’t slip and get scratched. If you notice something doesn’t fit, it’s better to take it apart again and check.
gasidney
23 Mar 2021 08:41
Take your time, work on a padded surface, and only fully tighten screws at the end. This way, you can avoid scratches and incorrect assemblies.
Giagau
23 Mar 2021 11:27
I would add that you should definitely check all parts for completeness and any damage before starting. Especially with BRIMNES, small transport damages can occur that may worsen during assembly – this way, you can address issues early.
Furthermore, I recommend installing the fittings gradually rather than all at once, and if using a cordless drill, be sure to set a torque limiter to avoid overtightening and damaging the material.
Small aids like felt pads under furniture can help prevent scratches on surfaces such as the floor after assembly.
