ᐅ How can I prevent Ikea Brimnes drawers from sticking?
Created on: 2 Aug 2024 10:17
gazar63
gazar63
2 Aug 2024 10:17
Hello everyone, I have a problem with my Ikea Brimnes drawers, which often get stuck or are difficult to open and close. I suspect that this is not only due to dirt but possibly also related to the mechanism or assembly. Can someone explain how I can prevent the Brimnes drawers from sticking when opening and closing? Are there specific adjustments, maintenance tips, or technical advice to ensure smooth and durable operation? Thanks in advance!
TEOZAR
2 Aug 2024 10:56
Hello gazar63,
First of all, that’s a good question, and I’m happy to provide a detailed answer, as this is a common issue with Brimnes drawers. Sticking can have several causes, and a solution is usually possible when considering all factors:
- Check the installation: Very often, the problem is that the drawers were not inserted perfectly straight or the cabinet frame is slightly warped. This causes the drawer to rub against the sides.
- Inspect the sliding rails: Brimnes drawers use simple metal or plastic runners. If they are dirty or small debris is caught inside, it can cause sticking.
- Consider the load: Overfilled drawers or excessive weight can overload the mechanics and increase the chance of sticking.
- Use lubrication: For plastic or metal runners, silicone spray can help ensure smooth movement. I find oil less suitable as it attracts dust.
So, I recommend: remove the drawer, clean the sliding rails, check that everything is aligned properly, and lightly treat the runners with silicone spray. Sorting the drawer contents by weight can also help.
If you wish, I can explain in more detail how to properly remove and reinsert the drawers. Best regards!
peovin
2 Aug 2024 13:08
Most of the time, the issue is due to incorrect alignment when inserting the drawer. Remove the drawer, check and clean the runners, then carefully reinstall it. If the drawer is heavily loaded, it is better to distribute the weight across multiple compartments.
Dilen
3 Aug 2024 09:45
Hello gazar63,
I can provide a more detailed response regarding your issue, especially concerning the technical aspects. The Brimnes system often uses plastic or steel drawer slides, which can become sticky if not installed properly or if subjected to mechanical stress. From my experience, the following points are important to ensure smooth and lasting drawer movement:
- First, always check if the drawer slides are correctly installed; the rails must be perfectly parallel and horizontal.
- The drawer sides should be free of any damage, as rough edges can catch on the slides. I recommend lightly sanding or removing small brittle spots if necessary.
- Another detail: some versions have integrated plastic dampers or stops, which can obstruct movement if improperly inserted.
- For maintenance: every few months, remove the drawer and wipe the slides with a dry microfiber cloth to prevent dust buildup that increases friction.
- Sometimes, gently readjusting the drawer by slightly shifting it up or down in the slide helps. The Brimnes system usually allows for a small amount of play.
Please let me know if you have already removed the drawers and inspected the slides more closely. Then we can address your situation more specifically.
Best regards!
Nabla64
3 Aug 2024 14:37
TEOZAR schrieb:
So I recommend: remove the drawer, clean the guide rails, check if everything is properly aligned, and lightly treat the slides with silicone spray.
Exactly, that sums it up well. I would add that with Brimnes drawers, it’s important to ensure that the slides on the sides of the carcasses are securely fastened and not loose. Any looseness can cause slight misalignment, which also contributes to sticking.
Additionally, I have personally had good results using PTFE spray. It is low-odor and doesn’t attract dust, while improving the smoothness over time. It’s important to let the spray sit for a few minutes after application before reinserting the drawer.
Summary:
- Remove the drawer
- Clean and maintain the slides
- Check the fastenings
- Slightly adjust the drawer when reinserting
If more detailed instructions for removal and reinstallation are needed, I’m happy to help.
Josefane
4 Aug 2024 11:22
gazar63 schrieb:
Can someone explain to me how to prevent the Brimnes drawers from sticking when opening and closing?
I find it interesting that the discussion often focuses on dirt and adjustments without really addressing the root cause of the design issue. The Brimnes series, due to the materials and construction used, is not designed for heavy loads or frequent use. Therefore, no fine-tuning or cleaning will permanently solve the problem.
It might be worth considering upgrading to higher-quality drawer slides or even converting to alternative mechanisms, rather than just applying surface-level fixes. Additionally, one should keep in mind that the weight and distribution of stored items are the main factors, as well as the possibly insufficient wood drying in Ikea products, which can lead to warping over time.
Has anyone had experience with retrofitting or replacing the drawer slides in Brimnes? I think this is an approach that deserves more attention.
