Hello everyone, I have a specific problem with the drawers of my Ikea Brimnes bed: they squeak every time I open and close them, which is quite annoying. I suspect the issue is with the tracks or slides, but I’m not sure how to permanently stop the squeaking without having to fully remove the drawer or cause any damage. Does anyone have experience with these BRIMNES drawers and can recommend a long-lasting solution? I’m especially interested in whether any particular maintenance, lubrication, or possibly replacing certain components would be effective, and if there are specific products to consider. Thanks in advance for any helpful advice!
The squeaking in BRIMNES drawers is often caused by the simple metal or plastic slides, which can harden or become dirty over time due to material wear or moisture. To prevent squeaking, I recommend a systematic approach: First, carefully pull out the drawer and check if the runners are clean and undamaged. Then, thoroughly clean all moving parts, especially where metal contacts metal or plastic contacts metal. After that, appropriate lubrication is necessary—silicone-based dry lubricants or PTFE (Teflon) sprays are suitable here because they do not stick or attract dirt. I would avoid traditional oils or greases, as they can trap dust and worsen the problem. Important: Before applying lubricant, it is essential to know whether the runners are metal or plastic to ensure compatibility with the lubricant. If the drawer has integrated full-extension slides, small adjustments to the screws can help improve the guidance. Finally, I would recommend setting a firm but not excessive clearance to avoid jamming, which can also cause squeaking. Are there already visible signs of wear on the sliding parts in your case?
kulau schrieb:
Finally, I would recommend setting a firm but not excessive clearance to prevent jamming, which can also contribute to squeaking.Thank you for the detailed explanation. Yes, the guide still looks quite intact, but I have noticed that the drawer sometimes slightly sticks or shifts a little when I pull it out.
One more question about lubrication: You mentioned dry lubricants based on silicone or PTFE spray – can I safely apply these to the plastic guides, or could this cause damage? Would it be advisable to test the spray first in an inconspicuous area? Are there any differences between these products that I should pay special attention to?
To prevent squeaking in Ikea BRIMNES drawers, a clean and dry track is the most important factor. The squeaking usually results from friction between the rail and the roller or from dust deposits that block moving parts. For lubrication, I recommend using a PTFE spray, as it reduces friction without becoming sticky. Silicone sprays are also suitable but may attract dust over time. It is essential to thoroughly clean the track and the roller or sliding rail from dust before applying any lubricant.
When dealing with plastic guides, caution is advised: PTFE is safe, but certain silicone products can attack plasticizers in the material. Therefore, always test on an inconspicuous spot first. Lubrication should also be applied sparingly. Using too much oil or grease can clog the drawer mechanism and eventually cause even more noise.
One more tip: the small rubber bumpers at the front of the drawer can also cause or amplify noises if they have hardened. Replacing them after a few years can often restore quiet operation.
I can fully understand how annoying squeaking can be, especially at night when you want to keep things quiet. In my experience, it’s not just lubrication but also correct installation that matters. When inserting the drawer, you need to pay close attention to the guides to make sure it doesn’t run crooked. Sometimes it also helps to slightly unload the drawers, meaning not to overfill them, because too much pressure can also increase the noise.
I can confirm that – replacing those buffers really helped me. It’s really a mix of several factors, and being patient during troubleshooting definitely pays off.
CHENFAR schrieb:
The small rubber buffers at the front of the drawer can also cause or amplify noises if they have hardened.
