ᐅ How can I prevent damage marks or dents on Malm drawers?
Created on: 8 Sep 2017 18:43
Lutemau
Lutemau
8 Sep 2017 18:43
Hello everyone, I currently have a problem with my IKEA Malm drawers: when opening and closing, the drawers often slam shut harshly, which is not only annoying but can also damage the material over time. My specific question is: what options or techniques are available to reliably prevent slamming or strong impacts in Malm drawers? Are there proven dampers, alternative slides, or tricks for smoother, controlled movement? I would appreciate tips that can be implemented without a complete reconstruction and that are specifically suitable for the Malm model. Many thanks in advance!
GIBAPO
8 Sep 2017 20:15
To prevent impact noise with IKEA Malm drawers, I recommend using damping elements. These can usually be attached to the sides or rear area of the drawer to cushion hard stops. There are many retrofit dampers made of plastic or rubber that are relatively easy to install. It is important to align the dampers precisely to achieve even braking effect. Alternatively, the drawer slides can be checked: if they are dirty or damaged, hard impacts can occur due to uneven movement. Cleaning and, if necessary, lightly lubricating them with appropriate sliding agents also helps. If available, the drawer should also be properly adjusted. Some users also recommend a self-adhesive rubber buffer strip on the back inside the cabinet to reduce the impact noise. In summary: add dampers, inspect and maintain the slides, and optimize the buffers at the stop.
pinpa
8 Sep 2017 21:05
GIBAPO schrieb:
To prevent impacts with IKEA Malm drawers, I recommend using damping elements.
That’s exactly my advice! I installed simple mini dampers on the inside of the drawer – it’s not complicated, but the difference is really noticeable. 🙂 Also, it’s worth checking if the drawer runs smoothly because small dust particles or clumps often get caught in the system, blocking the soft glide. A little lubricant can work wonders here, but use it sparingly and make sure it’s silicone-based to avoid stickiness. 😉
What also helped me was a barely visible rubber buffer where the drawer hits the cabinet frame. A small effort, big effect for quiet closing. A drawer that closes quietly makes weekend mornings even more enjoyable. :-) Hope you find the right solution for your Malm!
Lyndon55
9 Sep 2017 07:28
Regarding the issue of banging noises with Malm drawers, I would like to share a simple, systematic approach based on my experience that is easy to understand, even for beginners:
1. Check the runners: First, make sure all drawer runners are clean and free of dirt. Contamination can quickly cause jerky movements.
2. Adjust the drawer: A drawer that is not correctly installed or bent runners can cause sudden snapping. Check whether the drawer is properly seated in the runners and realign it if necessary.
3. Install dampers: There are specific damping inserts available for Malm drawers (e.g., small silicone or plastic buffers) that absorb the impact energy. These dampers can be installed alternately on the left and right sides or singly at the rear impact point.
4. Buffer strips on the cabinet: Adding a thin rubber or felt strip inside the cabinet at the contact point can help reduce the impact—especially if dampers alone are not sufficient.
5. Maintain the runners: After cleaning, I recommend using a silicone-based spray to ensure smooth gliding. Please avoid using oil on metal parts, as this attracts dust.
In summary: Identify the cause (dirt, misalignment) and then add dampers or buffers. When applied correctly, these small measures significantly soften drawer closing, protect the material, and extend the drawer’s lifespan. Good luck!
