Some time ago, I bought a few Malm furniture pieces from Ikea, especially dressers and nightstands from this series. Unfortunately, I am increasingly noticing that some of the surfaces and edges are slightly warping – in some cases, the fronts are bowing, and the drawers no longer slide smoothly. I have done some research and suspect that the material (particleboard with a foil coating) is particularly sensitive to moisture and temperature changes.
My specific question: What measures do you recommend to effectively prevent warping in Malm furniture? Are there particular care or storage methods that help keep the material stable? I am interested in practical tips that can be applied in everyday life, as well as basic advice on what to consider regarding placement and use to maintain the furniture’s shape and stability for as long as possible.
I would really appreciate any helpful responses!
Good morning,
we should not overlook the aspect of mechanical stress on the furniture. Although the Malm series is stable, the individual components made of particleboard have their limits when overloaded.
I recommend the following points:
1. Do not place excessive loads on the drawers, especially avoid placing heavy objects on top of the dresser that could put excessive strain on the material.
2. Ensure the furniture is level. Even a slight tilt of a few degrees can cause pressure points and tension on individual panels, which can promote deformation over time.
3. Load the drawers evenly and avoid filling only one side heavily.
Exactly.
Prevention therefore begins not only with care and placement but also with sensible use.
ODINFLO schrieb:
Uneven load distribution can promote deformations
Exactly.
Thank you all for the helpful and detailed advice so far; it has really helped me a lot! Especially the information about the environment (humidity and distance from the wall) and the load were new to me.
I have a quick follow-up question: Are there any experiences with special protective films or sealants that can be applied to Malm surfaces to make them more resistant to moisture? I would prefer not to damage the original surface but am considering protecting the material a little, especially since the furniture is partly located in a rather damp basement room (not directly exposed, but nearby).
Or would you rather advise against it?
RonJarrett14 Mar 2021 15:40Regarding iwandu’s question about protective films or sealants:
From my professional experience, the surface coating of Malm models is very thin and delicate. While an additional protective layer can be applied, there are risks involved:
- Many sealants chemically react with the coating, which can cause it to dissolve or discolor.
- Protective films must be applied precisely and without air bubbles, which is difficult without professional equipment.
In my experience, the best protection is to consistently avoid moisture and mechanical stress, as described in earlier posts.
One exception might be a sealant suitable for plastic surfaces that protects against moisture, but it should be tested on inconspicuous areas before full application.
In general, I advise against applying sealants yourself on Malm furniture.
It’s great to see so many well-founded tips gathered here!
@iwandu, I completely understand that you want to give your furniture the best possible protection. From my own experience: the combination of good room ventilation, keeping some distance from the wall, and regular checks has worked wonders for me.
I can confirm that.
Try measuring the room’s humidity with a small hygrometer – often a simple digital device is enough to keep track of the indoor conditions. Especially in older houses or basements, humidity levels can fluctuate significantly.
And one last tip: if you live in rooms with high humidity, avoid placing furniture directly against exterior walls. Moisture tends to settle there during cold seasons and can cause damage.
Good luck with everything!
RonJarrett schrieb:
The best protection is consistently avoiding moisture and mechanical stress
I can confirm that.
Hello again,
I just want to briefly remind everyone that proper installation is important. A few screws not tightened correctly or parts assembled slightly out of alignment can cause loads to be distributed unevenly.
I once had a dresser with a drawer that stuck. When I went through the troubleshooting steps, I noticed that two screws were slightly loose. After carefully tightening everything, the furniture became more stable and seemed to warp less.
That’s why it’s especially worth following the instructions carefully and paying close attention during assembly— even if it can be a bit frustrating at times.
Wishing you all a relaxing day! 🙂
