ᐅ How can I prevent damage to the Ikea Pax wardrobe when used by children?
Created on: 22 Oct 2024 08:37
BiluronHello everyone, I have a specific question: How can I prevent damage to an Ikea Pax wardrobe when it is used daily by children? Specifically, I am interested in how to avoid scratches, dents, or damaged fittings. It is especially important to know which protective measures or accessories have proven effective in maintaining the stability and appearance of the cabinets over time, without unnecessarily restricting the children’s use. I would greatly appreciate any tips on proper assembly, reinforcing the components, and child safety.
Hello Biluron,
First of all, it’s great that you are approaching this proactively, because when children use the Pax system daily, wear and tear or damage can easily occur, which can be prevented. Common causes of damage often include improper installation, overloading, and actively climbing on or hanging from the wardrobe doors.
I recommend the following measures:
- Always secure the wardrobe to the wall, even if Ikea usually recommends this.
- Attach soft edge protectors or bumpers on the inside to absorb impacts.
- Use or retrofit hinges with damping (such as soft-close mechanisms).
- Choose more robust, non-slip handles that are less likely to break.
- Avoid overloading shelves and distribute weight evenly.
- Clearly explain to children that climbing or hanging on the wardrobe is not allowed.
- Consider using plexiglass fronts or protective films to prevent scratches.
If you plan to use specific components, careful planning of the internal layout is crucial to avoid unnecessary stress. If you like, I can provide more detailed advice on specific accessories or installation tips.
Kinbu schrieb:
Install or retrofit hinges with damping (such as soft-close mechanisms).Yes, exactly, soft-close hinges make a big difference. They prevent loud slamming and noticeably reduce stress on the fittings.
flo-Theres22 Oct 2024 14:23I would add: In addition to secure fastening and using durable components, regular maintenance is important. Check the screws and hinges from time to time, especially if children use the area frequently, as things can quickly become loose. Choosing the right interior fittings can also help reduce damage – for example, sturdy baskets instead of simple shelves, particularly for toys or clothing that are often moved.
warrenka5723 Oct 2024 07:56I can understand well how quickly you start to worry when the children are climbing on the cupboard. What helped me was setting a clear rule: no climbing or leaning on the Pax wardrobe, combined with a small reward when they follow it. I secured the wardrobe doors with child locks that are not too hard to open but reduce the strain. There were concerns about whether this would be annoying, but the children got used to it quite quickly. This way, the wardrobes stay in better condition for longer, and I feel more at ease.
