trayvette13 Nov 2020 08:12Hello everyone,
I recently acquired several Malm furniture pieces from the well-known Swedish furniture company and would like to know how to effectively prevent cracking in these items. Specifically, I am concerned about using them in a typical living environment where temperature fluctuations and humidity are common.
I am interested in whether there are specific care methods or home remedies that are particularly suitable for the melamine resin or surface to avoid stress in the material. Additionally, I would like to know if there are any surface care products that have proven effective as protection.
I would also appreciate tips on the best placement of the furniture (e.g., distance from heaters or windows) and general advice on handling and cleaning.
Thank you in advance for your expertise!
reoleon4713 Nov 2020 08:45Wow, that’s a really important question! 🙂
I once had an issue with cracking in a Malm wardrobe because I placed it directly next to the heater. My advice: Always keep a distance from heat sources!
Additionally, I maintain my furniture using a special wood and melamine care product that I bought at the hardware store. It protects the surface and keeps it supple.
This is really great because it helps the furniture last much longer without damage! :-)
Hello trayvette,
I would like to address the issue more systematically. Cracking in Malm furniture usually occurs due to stresses within the material caused by differences in moisture and temperature. Malm furniture is primarily made from particleboard with a melamine resin coating, which is relatively durable itself, but the particleboard core is sensitive to environmental conditions.
Important recommendations:
1. Keep a distance of at least 30 cm (12 inches) from radiators and direct sunlight.
2. Maintain a stable indoor climate: ideal is around 40-60% relative humidity and 18-22 °C (64-72 °F).
3. Avoid cleaning the furniture with excessive moisture! Liquid can penetrate the wood and cause it to swell.
4. Use mild cleaning agents, preferably pH-neutral and designed specifically for coated furniture.
Additionally, products like polymer-based furniture polish can be used, but be careful—too much polish can become sticky or attract dirt.
In summary: preventive care is better than repairing damage afterward.
I want to go into more detail here, as this topic is crucial for many people.
First, it’s important to understand that Malm furniture, as mentioned, is made from substrate panels (often wood-based panels) coated with melamine resin foil. While this foil is relatively resistant to moisture and mechanical impact, it cannot fully compensate for stresses.
Cracking is primarily caused by the expansion and contraction of the chipboard core. This happens when the ambient humidity fluctuates or if the furniture dries out too much, for example, due to heat from radiators.
The following steps are particularly important:
1. Moisture measurement: If possible, measure and monitor the room humidity with a hygrometer.
2. Create stable conditions: This means maintaining consistent temperature and humidity. A humidifier can be very helpful during winter.
3. Proper cleaning: Do not use water or harsh cleaning agents. A slightly damp cloth is sufficient, followed immediately by wiping with a dry cloth.
4. Avoid excessive load on the furniture that could locally deform the chipboard.
5. Special care products: Wax-based or light oil products designed for melamine surfaces can keep the surface flexible, but always test first in an inconspicuous area.
6. Do not place furniture directly next to cold or hot windows; avoid drafts.
I would also like to know how long the furniture has been in use and if cracks are already visible, as this affects further options for action.
trayvette13 Nov 2020 14:13Surela schrieb:
I would like to know how long the furniture has been used and if any cracks are already visible?\The furniture is about 3 months old, and so far I have noticed small hairline cracks on the edges of a chest of drawers.
The furniture is actually positioned quite close to the window. The heating source is a bit further away.
So far, I have been cleaning with a damp cloth and mild dish soap, although I try not to let the water sit on the surface.
Do you think it is too late to prevent the cracks, or can I stop their development with targeted measures?
