ᐅ How do I plan the optimal IKEA Metod kitchen lighting?
Created on: 6 Aug 2015 09:42
Kenneth33
Kenneth33
6 Aug 2015 09:42
Hello everyone, I am currently planning my new kitchen based on the IKEA Metod system and am focusing heavily on optimal kitchen lighting. My main goal is to achieve efficient, comfortable, and functional illumination that ideally lights both the work surfaces and the room itself without causing glare or casting shadows.
Specifically: What is the best way to plan the positioning and selection of IKEA Metod-related lighting components? Which types of lighting (e.g., accent lighting, under-cabinet task lighting, ambient lighting) and light sources are recommended to create a coherent and flexible lighting concept? Are there proven tips for integrating LED strips into wall cabinets or for using spotlights?
Additionally, I am interested in practical advice on control options—such as switches, dimmers, or smart solutions—within the IKEA context.
I look forward to your experiences and suggestions, including technical details or alternatives to the standard IKEA products.
lenren
6 Aug 2015 11:03
Basically, always illuminate work surfaces intentionally, for example with LED strips under wall cabinets. A separate dimmer is useful for adjusting the brightness. Ceiling spotlights can be used for general lighting but should not be too bright to avoid glare.
BLAKEO
6 Aug 2015 13:28
lenren schrieb:
A separate dimmer is practical for adjusting brightness.
Dimming is certainly useful, but the question is how well the IKEA systems actually support it. From my experience, the IKEA LED modules are sometimes technically limited when it comes to dimmability and color temperature.
Additionally, I would generally question relying solely on IKEA products. There are LED modules available with more neutral light tones and better color rendering that can be integrated seamlessly and are more sensible in the long term. While smart control integration via Tradfri or alternative systems is convenient, it often conflicts with the planned wiring setup.
My advice: first define the lighting requirements in terms of lux values, then determine the combination of light sources. Relying blindly on IKEA lighting can limit the quality of the overall planning.
chenlen
7 Aug 2015 08:17
For optimal planning of the IKEA Metod kitchen lighting, the following steps should be systematically followed:
- Determine the room size and exact work surface areas: Ideally, base the required lighting levels on this, aiming for around 500 lux for work surfaces.
- Choose the type of lighting: Direct lighting under wall cabinets, supplementary ceiling lighting as general illumination, and possibly accent lighting.
- IKEA LED strips are well suited for work surface lighting; however, it is recommended to pay attention to the quality of the LED chips (CRI > 80) for better color rendering.
- When positioning, it is advisable to place the LED strips centrally under the wall cabinets and, if necessary, use glare-free covers.
- Control: Dimmers help avoid excessive brightness. Integrating simple switches in parallel with the main lighting is also practical.
Finally, it is important to plan the wiring routes in advance to allow for easy expansion later on. Good documentation of the lighting installation simplifies future modifications.
MAVERICKKA
7 Aug 2015 10:39
chenlen schrieb:
For positioning, it is recommended to place the LED strips centrally beneath the wall cabinets and, if necessary, use non-glare covers.
I agree with this but would like to add that the glare effect largely depends on the beam angle quality of the LED modules. IKEA offers suitable covers, though they are quite general-purpose. If glare remains an issue despite the cover, it is worth considering alternative LED profiles with optically optimized diffusers, which are available from accessory suppliers.
BLAKEO schrieb:
There are LED modules with more neutral light colors and better color rendering that integrate seamlessly and are more sensible in the long term.
I think this is an important point to consider during planning. Good lighting makes a real difference, especially when it comes to white and colorful foods, both in terms of aesthetics and cooking accuracy.
Finally, I would also recommend checking whether the wiring layout and the switching concept are compatible with the IKEA components. This helps avoid later modifications and confusing installations.
