ᐅ How do I design a custom IKEA PLATSA closet as a DIY project?
Created on: 27 Aug 2018 08:42
Neope
Neope
27 Aug 2018 08:42
I am currently planning to enhance my living space with a custom-designed IKEA Platsa wardrobe, which I want to build entirely myself as a DIY project. However, I want to approach this as efficiently and error-free as possible and have a few specific questions regarding planning and execution:
- How can I systematically plan to ensure I select the correct dimensions, modules, and accessories?
- What critical points should I keep in mind regarding stability and assembly, especially when adapting the wardrobe to my specific room requirements?
- Are there established methods or tools to visually model the design in advance and identify potential mistakes early on?
- Which materials or small additions from a hardware store or elsewhere should I consider to improve the functionality and appearance of the Platsa wardrobe?
I look forward to well-founded advice and your experiences to help me carry out this DIY project as smoothly as possible!
O
olivernu
27 Aug 2018 10:17
Planning a custom IKEA PLATSA wardrobe mainly requires precise measurement of the space and careful consideration of the functions the wardrobe should serve. It is helpful to start by measuring the available area with a tape measure, while also marking electrical outlets, radiators, and door swing areas.
An important aspect is the selection of modules: PLATSA offers various depths, widths, and heights, which increases flexibility. However, you should ensure that the connecting elements fit properly to guarantee stability.
It is practical to use IKEA’s planning tool, which provides quite a good visualization. During this process, it is important to regularly verify that the dimensions and accessibility are correct.
If special adjustments are needed, it is advisable to add suitable wooden strips or reinforcements from the hardware store, especially for larger constructions or if the wardrobe is to be wall-mounted. A solid fixing is also crucial for safety.
LENNAU
27 Aug 2018 13:39
Hello Neope,
I would like to explore your considerations a bit further because, with a DIY project like this, the foundation is often crucial.
- Measure the space: In addition to height, width, and depth, you should also take ceiling height and any sloping ceilings into account.
- Define functions: Do you need more storage for clothes or for books? Or should the wardrobe possibly also serve as a room divider or be designed with special doors?
- Planning tools: IKEA offers the PLATSA planner online, which is great but can have limitations if you want very custom solutions. Sometimes a hand-drawn sketch helps to work through your ideas.
- Assembly: Usually, assemble the parts fully before final installation to check for proper fit.
olivernu schrieb:
It helps to first measure the available space with a tape measure, also marking outlets, radiators, and door swing areas.
That’s a good tip because small obstacles can otherwise cause big problems.
giabau
28 Aug 2018 07:26
I would like to provide a simple structured process that can be helpful when planning a custom IKEA PLATSA wardrobe as a DIY project:
1. Assessment:
- Measure the room accurately and create a sketch.
- Mark critical spots such as power outlets, radiators, or light switches.
2. Objectives:
- Consider what the wardrobe should achieve (storage, display, room divider).
- Think about which types of doors or drawers you need.
3. Module selection:
- Review the various PLATSA modules with variations in height, depth, and width.
- Keep in mind that different modules have different load capacities.
4. Planning with digital tools:
- Use the IKEA PLATSA planner to create an initial virtual model.
5. Assembly planning:
- Study the assembly instructions carefully and plan the individual construction steps.
- Consider additional mounting materials that might be needed (screws, wall plugs/dowels, possibly wood reinforcements).
6. Additional materials:
- Depending on the room and wardrobe concept, extra handles, lighting (LED strips), or back panels might be desired.
7. If possible, do a dry fit and positioning in the room before securing everything permanently.
Tip: Avoid assembling the wardrobe on very uneven floors, as this can cause stability problems.
In general, patience and precise work are key to success in such custom DIY projects.
temeli
28 Aug 2018 17:04
Hey Neope!
I recently built my own PLATSA wardrobe and can only encourage you to give it a try—the modules are really versatile! What helped me a lot was to pause regularly and check that everything fits perfectly.
giabau schrieb:
If possible, try assembling and fitting it loosely in the room before you fix everything permanently.
That was key for me! I even temporarily connected some modules and moved them around the room to find the best spot.
A small bonus tip: with the doors, make sure they open and close smoothly without resistance. At first, I wanted to install some fancy doors, but they didn’t quite fit in the end.
I also secured the wardrobe to the wall using appropriate wall anchors, so it stands very firmly. If you commit to the planning, this will definitely be a success for you!
Juan31
29 Aug 2018 09:13
As a supplement: A structured approach to your DIY project with the PLATSA wardrobe is essential for a good result.
- Measurements: Use a laser distance meter whenever possible for maximum accuracy.
- Load distribution: Especially for tall wardrobes, ensure the load is evenly distributed to prevent deformation.
- Modular flexibility: Take advantage of the variability in widths and depths to adapt individually to the space, but avoid mixing too many different modules without a systematic connection.
- Accessories: In some cases, additional fittings, such as corner brackets or double screw fastenings, are useful.
- Documentation: Keep your planning in writing and create a materials list to avoid reordering and surprises.
LENNAU schrieb:
Planning tools: IKEA offers the PLATSA planner online, which is great but may have limitations,
Exactly, in addition to the planner, I recommend making your own sketch on graph paper (millimeter) to get a better feel for proportions.
