ᐅ How can I permanently fix a squeaking Ikea Metod kitchen cabinet door?
Created on: 5 Dec 2022 10:23
Amrgi
Amrgi
5 Dec 2022 10:23
Hello everyone, I have an issue with my Ikea Metod kitchen cabinet door that has started squeaking when I open or close it. This seems to be a common cause, but it obviously isn’t easy to fix permanently since the problem keeps coming back despite several attempts. My specific question is: How can I repair a squeaking Ikea Metod kitchen cabinet door so that the squeaking is permanently eliminated?
I have already cleaned the hinges and treated them with some silicone spray, but that only helped temporarily. Are there any lubricants specifically recommended for the Metod series or mechanical adjustments I can make?
I am especially interested in whether there are certain adjustment options on the hinges that can prevent the squeaking, or if it makes sense to replace the hinges. Any tips on long-term maintenance would also be great. Thanks in advance for your experiences and advice!
anfeteo
5 Dec 2022 11:44
Hello Amrgi,
I’m happy to explain how I permanently eliminated the squeaking on Metod doors – including a step-by-step guide:
- First, you should thoroughly clean the hinges to remove all dust and old lubricants. Use a lint-free cloth and isopropanol (better than just cleaning with water or soap).
- Then I recommend a special lubricant that doesn’t become sticky and lasts a long time. Silicone spray usually doesn’t hold up permanently; better options are dry lubricants containing Teflon or PTFE. These can be found in well-stocked hardware stores.
- Important: Apply the lubricant sparingly and precisely to the moving parts of the hinge, not on the door surface, to avoid stains.
- After that, you need to readjust the hinges. Metod hinges have screws to adjust depth, height, and lateral position. If the door puts too much pressure on the hinge, it will squeak. So adjust until the door closes smoothly and without resistance.
- Finally, you can slightly tighten the hinge screws, but not too much, as that can cause friction again.
I’ve had no squeaking for over a year using this method.
Summary: Thorough cleaning, the right lubricant, careful adjustment, and moderate tightening of the screws are the key points.
If you need more details about the screws, I’m happy to explain.
NOAHSAU
5 Dec 2022 13:05
anfeteo schrieb:
Silicone spray usually does not last long, special dry lubricants containing Teflon or PTFE are better.
I have to disagree here – silicone spray is often criticized, but it is actually the most flexible and durable solution against squeaking noises. Sure, it doesn’t last forever, but when applied correctly, it can keep things quiet for several months.
I think the idea of switching to PTFE is a bit overstated – the difference is minimal, and in practice, I hardly notice it.
Also, squeaking usually isn’t just caused by the lubricant but by low-quality hinges or incorrect installation. I would focus more on checking or replacing the hinges rather than constantly reapplying lubricant.
In short: lubricant alone rarely provides a lasting solution. The mechanics and quality of the mounting are much more important.
Keatondra
6 Dec 2022 09:17
Amrgi schrieb:
Are there any recommended lubricants or mechanical adjustments specifically for the Metod series that I can apply?
Hello Amrgi, I have encountered this issue several times and can confirm that a combination of lubrication and adjustment is often the key. The Metod hinges are designed to be adjustable in three directions – height, width, and depth. This usually helps prevent tension that causes squeaking.
I recommend the following:
- Loosen the hinges, remove the door, and closely inspect the joints. Sometimes there are foreign particles or dust buildup deep inside.
- Check that all screws are tight – loose screws can cause movement that leads to friction noise.
- Use a PTFE-based lubricant or graphite powder for a dry solution that won’t attract dirt. Oil or grease can draw in dust and make the problem worse.
- If you have no experience with adjustments: Metod hinges usually have small screws with springs to regulate tension. Turn these carefully to make the door move more freely.
- Also check if the door rubs against the bottom edge. This often produces noises that are mistakenly attributed to the hinges.
If you like, I can also provide a detailed step-by-step guide with pictures and explanations for each screw. That makes it even easier.
PAUREO54
7 Dec 2022 16:38
Short and direct:
- Clean the hinge
- Apply PTFE spray to the joint
- Slightly loosen the hinge screws, then tighten them again
- Adjust the door properly (especially laterally)
This will stop the squeaking. With Ikea Metod, this is standard. Nothing more is needed.
