ᐅ How can I permanently fix a squeaking Ikea Metod cabinet door?
Created on: 28 Nov 2022 09:17
Nicona
Nicona
28 Nov 2022 09:17
I have an Ikea Metod kitchen cabinet door that makes a very annoying squeaking noise every time I open or close it. The noise seems to be coming from the hinges, at least that’s my assumption. I have been dealing with this issue for a few weeks and have tried several home remedies like silicone spray and WD-40 – but the effect is only temporary, and the squeaking always comes back.
My question is: How can I permanently fix the squeaking Ikea Metod door? Is there a method or a specific procedure that works long-term? Do I need to replace the hinges entirely, or is there another more durable solution?
I would appreciate it if you could share your experiences or tips on how to reliably and permanently solve this problem. Thanks in advance!
Jorgela
28 Nov 2022 09:45
The squeaking usually comes from metal rubbing against metal at the hinges. It is best to completely remove all hinges, clean them, and then lightly lubricate with a suitable lubricant (e.g., sewing machine oil). WD-40 or silicone oil can help temporarily but are not a long-term solution. If the hinges are damaged or too old, replacement is the only option.
Deandre
28 Nov 2022 11:02
Nicona schrieb:
My question is: How can I permanently fix the squeaky Ikea Metod door?
Hello Nicona, that’s an important question, especially since temporary solutions can become annoying over time. Usually, the issue is caused by the hinges drying out or small contact surfaces creating too much friction.
My recommendation:
- Remove the door and take the hinges off completely.
- Clean the hinges thoroughly with a lint-free cloth.
- Use a light, non-resinous oil for lubrication, preferably a special household or machine oil.
- Apply the oil precisely to the moving parts, using only a small amount to avoid any dripping onto the door or cabinet body.
- Reattach the door and test its movement; if needed, slightly adjust the screws.
This usually keeps the squeaking away permanently, as long as you repeat the maintenance every few months. If the hinges are already damaged, I would consider an original replacement from Ikea.
I hope this helps!
gesar32
28 Nov 2022 13:29
For a permanent repair of a squeaking Ikea Metod door, a systematic approach is necessary.
- Identify the cause: In most cases, the squeaking is due to insufficient lubrication or wear on the hinges.
- Clean: Remove the hinges and thoroughly clean all metal parts, including small traces of dust or dirt.
- Lubricate: Preferably use a light machine oil that neither hardens nor attracts dust.
- Replace: If there is visible wear on the hinge pins or plastic components, replacing the hinges is the best long-term solution.
Simple cleaning and lubrication often are not enough if material fatigue is present. When in doubt, a combination of both methods helps. This usually happens with furniture that is frequently used over several years.
Additionally, I recommend tightening the screws during the repair, as loose hinges can also cause squeaking.
O
ODINFLO
29 Nov 2022 07:55
Deandre schrieb:
Usually, it’s because the hinges dry out or small contact surfaces create too much friction.
I think this is a somewhat simplified explanation. There are definitely cases where the squeaking isn’t just caused by lack of lubrication but also by insufficient design or material choice of the IKEA hinges.
Therefore, I would ask whether it is known for Metod hinges to squeak only for a short period and then lubrication alone is not a lasting solution.
Also: Has it been verified that the noise really comes from the hinges? Sometimes closely fitting wood or plastic parts can also cause noises due to minimal vibrations.
I have no objection to using WD-40, but in the long term, oil is often better, as WD-40 can sometimes promote quick dirt buildup and later swelling.
It is also important to properly align the door, as bent or incorrectly adjusted doors can put more strain on the hinges, which then squeak faster.
LEEJU
29 Nov 2022 10:22
Summary of my experience:
- Remove hinges
- Clean thoroughly
- Lubricate with machine oil
- Tighten screws
- Check if the door is properly aligned
However, if the system is older and the noises persist, the only solution is to replace the hinges. Metod spare parts are affordable and easy to find.
