ᐅ How do I paint Malm furniture?
Created on: 3 Jan 2023 08:23
mudeo
I have decided to repaint my Malm furniture from IKEA because I no longer like the white finish. Could someone please explain in detail the best way to proceed to achieve a good, even result? I am especially interested in the preparation steps, which types of paint or finishes are suitable, and if there are any special techniques for the surface. I would also appreciate advice on whether I should disassemble the furniture or if it can be painted as a whole. Thanks in advance!
CARLA
4 Jan 2023 08:05
In addition to the previous discussion: The surface of Malm furniture is generally challenging for painting because it is melamine-coated. Therefore, using a primer specifically designed for plastics is important. Thin, multiple layers of paint are necessary to prevent cracking. Furthermore, painting should be done at appropriate temperatures and humidity levels, ideally around 20°C (68°F) and 50% relative humidity.
mudeo
4 Jan 2023 10:23
Thank you for the advice, I wasn’t aware of that. Should I therefore avoid using regular wood paint and instead use a special plastic paint? If so, can you or someone else recommend a specific product type or brand? I want to avoid buying the wrong paint.
Dopoki
4 Jan 2023 11:45
Yes, exactly. Because of the melamine-coated surface, a paint formulated for plastics is suitable. A two-component polyurethane (2K PU) paint or a special acrylic plastic paint works well. Brands like 'Hammerite' or 'Kreidezeit' offer suitable products that adhere well and provide good coverage. It is also important to use an appropriate adhesion primer approved for plastics before painting.
Jorgela
4 Jan 2023 12:25
I have had good experience with 2-component acrylic paints; they are durable and easy to apply. Thin layers with intermediate sanding are important for a smooth, high-quality finish.
Kinbu
5 Jan 2023 09:56
mudeo schrieb:
So should I avoid using regular wood lacquer and instead use a special synthetic lacquer?
I would confirm that. Regular wood lacquers usually do not adhere well to melamine-coated surfaces. Using a special synthetic bonding primer plus a suitable lacquer is definitely more reliable. If you can disassemble the furniture pieces, I recommend at least treating the fronts separately, as this allows much better control and helps prevent runs caused by hard-to-reach areas.
