ᐅ How can I paint Ikea Besta cabinet doors evenly and so the finish lasts?
Created on: 24 Jun 2016 18:07
alinpoHello everyone, I am planning to repaint my Ikea Besta fronts because they look quite worn in their current condition, and I want to achieve a fresher appearance with a durable surface. My specific question is: How do I paint Ikea Besta fronts evenly and in a way that ensures the surface is resistant to scratches and abrasion, while also resulting in a smooth, visually appealing finish? I already have some experience with sanding and priming but am unsure which type of paint is best and what the ideal complete process should be (including preparation, paint application, drying times, and any intermediate sanding). I would greatly appreciate any advice on materials, tools, and potential pitfalls.
edisondan24 Jun 2016 18:39To achieve a consistently painted and durable surface on Ikea Besta fronts, careful preparation is essential. First, thoroughly clean the fronts, then scuff the surface with fine sandpaper (grit 240-320) to improve paint adhesion. It is recommended to use two-component acrylic or polyurethane (PU) paints, as they form a hard and resilient layer.
Apply the paint using high-quality rollers or a spray gun to minimize streaks. Between coats, lightly sand with very fine sandpaper (grit 400-600) to enhance smoothness. Each coat must dry according to the manufacturer’s instructions, usually 4-12 hours. Finally, applying a clear coat with a matte or satin finish is recommended for protection.
Important: Work in a dust-free environment to avoid inclusions. The integrity of the substrate is crucial for durability.
edisondan schrieb:
The use of 2-component acrylic or PU coatings is recommended, as they form a hard and durable layer.I can confirm this, but I would like to add that the preparation of the surface is especially crucial for Besta fronts made of coated particleboard or MDF. The surface is often melamine-coated, which makes paint adhesion more difficult. The following procedure has proven effective:
- Remove the fronts
- Clean with a degreasing agent
- Lightly sand the surface using a sanding pad or very fine sandpaper (at least 240 grit) to break the gloss of the melamine coating
- Apply an adhesion promoter or primer specifically designed for melamine or plastic surfaces
- Apply several thin coats of high-quality 2K acrylic or PU coating to achieve a smooth surface
- Sand lightly (grit 400 or finer) between each coat before applying the next
This process significantly improves adhesion and prevents the paint from peeling later on. When choosing the coating, it is advisable to use solvent-free options if working indoors.
I am interested in how you manage dust control and the indoor climate during your work – these factors play a major role in achieving a perfect finish.
poted schrieb:
I’m interested in how you manage dust control and indoor air quality in your workspace – these are crucial for a perfect finish.Thanks for the tip, poted. I work in an enclosed, well-cleaned room with as little airflow as possible. Dust-free conditions are only partially achievable, so during and after painting, I try to minimize air movement as much as I can. At the moment, I’m still undecided whether to use a roller or a small spray gun; spraying seems to have an advantage, especially for small furniture pieces like fronts, to avoid streaks. What do you think about using a spray gun as a hobbyist? Is a simple airbrush sufficient, or should it be a small compressor setup?
alinpo schrieb:
What do you think about using a spray gun as a hobby user?For a truly even surface, spraying with a proper paint gun plus compressor is technically ideal, but it can be challenging for beginners because it takes some practice to maintain the right distance and achieve proper overlap. A small compressor with a simple suction cup gun can be sufficient if you take your time to develop the technique and work carefully.
Alternatively, a good foam roller designed for paint can achieve equally good results if the paint is applied thinly and spread evenly. It is important to apply the paint in several thin layers and lightly sand between coats.
Dust is a critical issue here. Masking off the work area and regularly cleaning the air helps, even though it doesn’t have to be a cleanroom environment.
edisondan schrieb:
Important: Work in a dust-free environment to avoid inclusions.I have to disagree here: Dust-free conditions are an ideal, but hardly realistic for DIY projects. It’s better to be prepared and know how to fix or conceal small mistakes. Sanding off a few dust particles and applying one last coat of paint will restore a flawless surface.
Also, the need for perfectly even paint is often overrated – slightly textured surfaces can look high-quality, perhaps even more characterful than a sterile plastic-like finish.
That’s why my point is: Pursuing too much perfection often ends up being perfection for its own sake, causing you to miss the chance for sustainable work using practical approaches.
