Hello everyone, I am planning to paint my IKEA Billy shelves but want to avoid damaging them during the painting process or preparation. My main question is: How can I properly paint Billy shelves without causing damage, ensuring a smooth surface without scratches, chipping, or bubbles?
So far, I have only lightly sanded the shelves but am not sure if I need a primer or if I can start directly with paint. I am also wondering whether it is better to disassemble the shelves and paint the individual parts or to paint the entire assembled unit.
Does anyone have experience with specific types of paint or techniques (e.g., spray paint, rollers, brushes) for Billy shelves? I would appreciate any tips and advice, including the recommended timing and drying time. Thanks in advance!
Hector schrieb:
What speaks against painting the entire shelf? I do see the risk of drips, but the fit remains accurateCompletely correct. However, I still recommend disassembling it because painted edges often get damaged during assembly.
If you paint the entire shelf, there is also a risk that storage components stick together or become difficult to install.
My advice: disassemble, then apply paint moderately, let it dry, and reassemble very carefully. Sanding between coats is essential to ensure a smooth surface.
Hey, I can definitely confirm the issue with blistering when painting – it’s great that you’re thoroughly covering the topic of disassembly! 🙂
My little tip: after sanding, I applied fine painter’s tape to protect the edges. This prevents cuts and chipping during painting.
Also, use spray paint in several thin layers. Let each layer dry properly – it’s really easygoing and results in a great finish. 🙂 Good luck!
JORDON schrieb:
fine painter’s tape applied. This prevents cuts and chipping during painting.This is a useful tip for protecting sharp edges when painting. However, I would recommend removing and replacing the tape before each coat to avoid wrinkles or unevenness in the finish.
Regarding the primer: There are special adhesion primers for melamine surfaces, such as zinc phosphate primers, which work very well.
Also, consider whether you prefer to use an electrostatic spray gun or a spray can, as this choice significantly affects durability.
Dirkmin schrieb:
Consider whether you prefer to work with an electrostatic sprayer or a spray canWow, that sounds like professional equipment. Especially for people like me who will probably do this only once, it seems too complicated. I would rather recommend not building up too much pressure and simply relying on good ventilation and patience.
You also need to give yourself some mental time. A little self-doubt is normal, but the result usually turns out better than expected.
Thank you for all your helpful contributions! To summarize, my understanding is: it’s best to disassemble the shelf parts, lightly sand them with 180-grit sandpaper, use a special adhesion-promoting primer, then apply several thin layers of spray paint with intermediate sanding using 320-grit sandpaper, and let everything dry thoroughly.
The tip about using painter’s tape on the edges is great, as well as the advice not to leave the tape on the paint before it is fully dry.
I will probably go with acrylic spray paints since I don’t have professional equipment. One last question: are there any specific products or brands you would recommend for primers and spray paints for this purpose?
Thanks in advance!
Thanks in advance!
