ᐅ How can I optimize the storage space in the IKEA Metod base cabinet?
Created on: 5 May 2022 09:14
laufation
I have been thinking for some time about how to best optimize the storage space in my IKEA Metod base cabinet. The dimensions are fairly standardized, but I feel that even with shelves or the standard drawers, the space is often used below its potential. Specifically, I am interested in which organizational systems, material utilizations, or additions I can use inside the base cabinet to make the most efficient use of the space for my kitchen appliances, supplies, and smaller items without compromising accessibility or stability. Perhaps someone has experience with custom inserts or alternatives like modular boxes that fit perfectly within the Metod frames. I look forward to tips, ideas, and also advice on mistakes to avoid.
Guyju
5 May 2022 15:42
laufation schrieb:
The point about adjustable partitions and the load capacity of the pull-outs sounds very relevant. The items in my cupboard vary quite a bit: heavier pots and pans at the bottom, supplies and smaller containers above, and sometimes kitchen tools like mixing bowls or measuring cups.
For your situation, I recommend:
- Zone 1 (bottom level): Fixed shelves for heavy pots and pans, without drawers, to safely support the weight
- Zone 2 (middle level): Pull-outs with larger compartments, for example with adjustable partitions, to neatly store bigger kitchen tools
- Zone 3 (top level): Drawers with small inserts for supplies that need to be easily accessible
- Bonus: Possibly a swing-out pull-out next to the cupboard (if space allows) to store taller appliances
This combination allows flexible use based on weight and frequency of access.
boelnu
6 May 2022 08:17
laufation schrieb:
I look forward to tips, ideas, and also advice on mistakes I can avoid.
From experience, I can say that you shouldn’t get discouraged if your initial organizing idea doesn’t work out. I had a similar experience: at first, I thought my boxes would keep things tidy, but in reality, the drawer often ended up messy. The important thing is to adapt the solution to your daily routine, not the other way around. Your question about custom inserts is very relevant – I have achieved better results using generic materials with small adjustments than relying on ready-made “magic solutions.”
enrique7
6 May 2022 09:03
boelnu schrieb:
It is important to adapt the solution to your daily routine, not the other way around.
This sentence describes the problem of many organization projects very well. People start with a theoretical ideal and overlook the practical suitability for everyday life. With Metod, this is not trivial either due to the standardized measurements. I would even recommend observing the usage shortly after larger changes and adjusting if necessary. Your openness is refreshing.
Elodie
6 May 2022 11:26
What I would like to add: Do yourself a favor and regularly close the fronts. This may seem trivial, but it helps prevent turning the order inside the base cabinet into chaos from the outside. If you think of the organization as a kind of "puzzle," it becomes easier to insert and adjust individual elements. Enjoying the process is also a big factor!
JAMESONB41
6 May 2022 12:05
One more tip: Use storage boxes in similar colors or transparent ones to make it easier to keep things organized. This way, all your items will visually appear as a cohesive group.
Jodyro
6 May 2022 14:50
Simply: Multiple hanging rails inside the base cabinet allow flexible rearranging of baskets and holders.
