ᐅ How can I optimize storage space in Ikea Metod tall cabinets to keep things more organized?
Created on: 7 May 2024 18:23
Momme45
Momme45
7 May 2024 18:23
Hello everyone, I am planning to make better use of the storage capacity in my Ikea Metod tall cabinets to create more order in my kitchen. Specifically, I want to optimize the existing compartments and shelves in the tall cabinet, as I feel that I’m not using the space efficiently, mainly due to the sometimes large distances between the shelves and the unclear layout. I want to avoid having to buy expensive organizers, but I am open to smart solutions and practical tips that have proven effective. How do you optimize the storage space in your Metod tall cabinets? What adjustments or tricks have helped you really maximize the usable area and keep the organization system clear?
Mufato
7 May 2024 18:47
The easiest way is to install additional shelves spaced apart from your existing ones. The Metod tall cabinets offer many options to choose the position individually. Use boxes or baskets for small items to keep everything in place and make them easier to access.
Lucien
8 May 2024 09:13
An important aspect of optimizing storage space in Metod tall cabinets is considering the maximum load capacity of the shelves, which the manufacturer specifies as 20 kg (44 lbs) per shelf. This ensures safe use of the shelves for heavier appliances or supplies. Additionally, I recommend using transparent storage containers, as being able to see the contents greatly improves organization. Using the inside of cabinet doors to attach small hooks or slim utensil holders is also an efficient way to keep frequently used items within easy reach while saving space. Furthermore, organizing items systematically by categories such as baking utensils, pots, or pantry goods is advisable, as this clear structure reduces retrieval times and sustainably improves the overall storage system.
U
uslis47
8 May 2024 15:36
Hello Momme45, I can understand your situation well. The Metod tall cabinets often have relatively large gaps between the shelves, which can quickly become impractical. If you haven’t tried it yet: IKEA offers shelves in various heights that you can use flexibly. This way, the interior space can be customized almost tailor-made. Additionally, I would recommend getting inexpensive modular container systems or stackable boxes to make better use of the height. For example, stackable boxes fit perfectly under a higher shelf, and smaller boxes on top can catch loose items. Drawer inserts inside the cabinet can also help to keep everything more organized. If possible, it can help to divide the cabinet into zones, for instance placing heavy appliances at the bottom and frequently used ingredients within easy reach at the top. This way, you minimize clutter. Finally, regular decluttering is important to ensure that nothing unnecessary blocks the space.
Kinbu
9 May 2024 08:54
Hi Momme45, I faced similar challenges and solved them by installing adjustable shelves with additional rail combinations. This lets you create multiple levels, significantly increasing vertical storage space. A tip from me: use shallow pull-out baskets or sliding wire baskets so you can easily reach items behind objects placed further back without having to empty everything. Another option is door organizers, which are especially useful for narrow spaces and for storing baking trays or spice bottles. The key is to really divide the space into small, functional zones. For example, in a tall cabinet, dedicate one section solely to baking utensils with appropriate boxes and sorting aids. This way, you avoid searching through clutter, and everything has its designated place. Also, consider whether multifunctional boxes are stackable. Thanks to the modular design of Metod, adapting the setup over time becomes easier once you start using assistive systems.
