ᐅ How can I optimize the lighting in Ikea Metod kitchens using LED strips?
Created on: 7 Feb 2015 10:03
troyli
troyli
7 Feb 2015 10:03
Hello everyone, I am currently planning to install LED strips to illuminate my Ikea Metod kitchen and wanted to ask for tips here in the forum on the best way to do this. Specifically, I am interested in how to most effectively position the LED strips to optimally light both the countertops and the kitchen cabinets. I am looking for advice on both the placement and the choice of the right brightness and color temperature. Are there particular models or mounting methods that are especially suitable? I am also interested in questions about wiring and power supply. Thanks in advance for your support!
LOPAU
7 Feb 2015 12:29
In principle, when lighting Metod kitchens with LED strips, it is best to aim for uniform illumination. I recommend mounting the LED strips directly under the wall cabinets to optimally light the work surface. It is important to use warm white LEDs with around 3000 Kelvin, as they provide pleasant light that highlights colors well. Installation is best done with aluminum profiles, which also act as heat sinks and ensure even light distribution. The wiring should be planned centrally to keep cables neatly hidden. If dimmable LED strips are used, the light intensity can be adjusted according to the mood, which I highly recommend.
Annedeo
7 Feb 2015 14:11
An important aspect already mentioned is the color temperature. Compared to cool white light, warm white appears much more natural and pleasant in the kitchen. I would also recommend planning for enough extension cables during the wiring phase and positioning the strips so that the light sources are not directly visible, as this can cause uncomfortable glare. A tip for installation: Ikea often offers their own LED strips for Metod cabinets, which integrate perfectly and are ideal if you prefer a straightforward solution. Otherwise, standard LED strips operating at 12 V can be used safely in the kitchen. The power supply should be a suitable adapter matched to the total length of the strips.
SINTAR
7 Feb 2015 15:47
So: LED strips under the upper cabinets, warm white, preferably dimmable. Cables hidden in cable ducts. Power supply sized appropriately. Done.
deoke
8 Feb 2015 09:06
I would like to delve a bit deeper into the technical aspects, as there are several factors that are often overlooked. When installing LED strips in an Ikea Metod kitchen, the exact mounting method is crucial. Aluminum channels are indeed the best solution: they help dissipate heat, which not only extends the lifespan of the LEDs but also ensures even lighting without hotspots. Additionally, I recommend using a frosted diffuser cover – this diffuses the light nicely and prevents glare. It is also important to consider whether the LED strips operate at 12 V or 24 V, as this affects the wiring. For longer strips, a parallel connection should be considered to avoid voltage drop and brightness loss at the end of the strip. The choice of power supply is also critical: it should provide a buffer of about 20% more capacity than the maximum consumption of the LEDs to ensure a reliable power supply. Finally, regarding color temperature: 3000 K, naturally, up to a maximum of 3500 K warm white – above this, the light quickly becomes cold and uncomfortable for cooking and work areas. When exactly do you plan to start wiring the kitchen? I can also recommend some brands based on my experience if you like.
troyli
8 Feb 2015 12:58
deoke schrieb:
For longer strips, you should consider wiring them in parallel to avoid voltage drop and brightness loss at the end of the strip.
Thank you, that sounds very helpful. I have two longer wall cabinets, each about 120 cm (47 inches) wide. Do you think it would be better to divide the LED strips into two sections each and wire them in parallel? That would be a bit more complicated in terms of wiring, but if it really makes a difference, it’s worth it.
deoke schrieb:
I also recommend fitting the strips with a frosted cover – this helps diffuse the light nicely and prevents glare.
Where can you find such covers? Unfortunately, Ikea doesn’t seem to offer these, right?
