ᐅ How can I optimize the interior of the Ikea BESTA unit for office supplies?
Created on: 13 Jan 2018 10:17
DUBUELHello everyone,
I recently bought an Ikea Besta cabinet, which I want to convert into an efficient storage solution for my office supplies. My goal is to optimize the interior space so that various office items like binders, writing materials, electronic accessories, and documents are well organized and easily accessible at all times. I want to make the best possible use of the available space—especially interested in how to increase flexibility through adjustable shelf heights, inserts, or drawers. I am also considering whether it is worthwhile to retrofit additional interior fittings, such as boxes, dividers, or special organizers for cables and pens. I would like to hear if anyone has experience with custom builds to adapt the interior individually and functionally without compromising the stability or design of the furniture.
In summary: How can I best optimize the interior of the Ikea Besta cabinet for various office supplies to create order and make the space flexible and clear?
Looking forward to your tips and suggestions!
jo-Fernand13 Jan 2018 11:04Basically, the BESTA system is very flexible, as it allows for compartments of varying heights and can be combined with drawers, doors, or open shelving units.
I recommend planning the interior modularly:
- Use height-adjustable shelves to fit folders and devices of different sizes without wasting space.
- To organize smaller office supplies efficiently, consider drawer inserts or boxes designed for this system – they help keep things tidy and prevent clutter.
- For cables and electronic accessories, flexible cable holders or small boxes that fit easily into the shelves are helpful.
When adding components, make sure they don’t obstruct access or compromise stability. It’s best to use plug-in systems or storage solutions that can be easily removed.
If your goal is to optimize the interior of the BESTA cabinet specifically for office supplies, I recommend the following structured approach:
- Take an inventory of the items to be stored, considering their size, function, and frequency of use.
- Plan the shelf division based on the items: for example, wide shelves for binders, small boxes or drawers for stationery.
- Use adjustable shelves from the BESTA accessories or similar.
- Implement storage boxes that are ideally stackable and possibly transparent to ensure quick access and clear overview.
- Manage cables with elastic bands or cable clips attached to the inside of the doors or behind the shelves.
A combination of adjustable shelf heights, clearly defined functions for each compartment, and the use of specialized organizers ensures the desired order and optimal use of space.
Hello DUBUEL,
To organize the BESTA cabinet optimally for office supplies, a good strategy is to combine adjustable shelf heights with internal organizers.
- You can flexibly adjust the shelves to fit A4-sized binders easily. You will likely need several different heights to accommodate both smaller and larger items.
- Using specialized organizers, such as pen holders, small boxes for paper clips, and other accessories, helps keep smaller items separated.
- Also consider thicker drawer inserts made of plastic or wood – these provide plenty of storage depth without creating clutter.
- For electronics, I recommend small cable boxes, which can also be DIY-made, to eliminate cable mess.
- If you have space on the inside of the doors, you can install small hooks or holders – this creates extra space for items like scissors or notepads.
Combining several different elements effectively will ensure strict order, clear overview, and optimal use of the available space.
jo-Fernand schrieb:
I recommend planning the interior modularly: That is correct, but it is important to differentiate how often each item will be accessed. A simple classification based on size is not sufficient.
Office supplies vary greatly in frequency of use – documents needed daily should be stored within easy reach, preferably at eye level, while less frequently used items can be placed higher up or lower down. This is an important ergonomic and organizational consideration that is often overlooked.
Furthermore, I would view the idea of DIY construction more critically. For most users, the effort is not worthwhile, especially considering that many interior organization systems are already available from IKEA, which are easy to assemble and match in design.
Finally, there is also the question of stability: DIY constructions may reduce the load-bearing capacity of shelves or compromise overall stability. To make a reliable decision here, the relevant technical specifications would need to be reviewed.
