ᐅ How can I optimize the installation of Ikea Metod kickboards with underfloor heating?
Created on: 17 Jul 2021 09:47
Siamakri
Siamakri
17 Jul 2021 09:47
Hello everyone, I am currently facing the challenge of optimizing the installation of Ikea Metod baseboards in an apartment with underfloor heating. Specifically, I want to know how to mount the baseboards so that they provide a clean finish while not interfering with the heat output of the underfloor heating. Are there any special installation techniques, spacing solutions, or materials that should be considered? I have heard that the traditional fixed installation directly on the floor can be problematic because the heat needs to circulate. I am also interested in tips for handling corners and transitions. Perhaps someone has experience with the combination of Metod baseboards and underfloor heating? Thank you in advance for your ideas and recommendations!
GU-LAU60
17 Jul 2021 10:12
Hello, I would not attach the baseboards directly to the floor but use small spacers, for example plastic blocks. This allows for sufficient air circulation. Also, make sure to use flexible joints at the corners to prevent any warping.
Palenar
17 Jul 2021 11:03
Basically, it is important to ensure heat circulation with baseboards installed over underfloor heating. The Ikea Metod baseboards are sturdy, but since they are relatively wide and fit tightly, I recommend the following step-by-step approach:
- First, the subfloor should be dry and the underfloor heating set to at least a low level to simulate later expansion.
- Then attach an underlay strip made of heat-resistant foam or narrow spacer glides to create a gap of about 5 to 10 mm (0.2 to 0.4 inches) from the floor. This creates an air gap necessary for better heat distribution.
- The baseboard is fixed with clips that allow slight flexibility. This prevents stresses caused by the floor expanding.
- For corners, avoid simply butt-jointing; instead, use small compensating pieces to accommodate movement.
I would also be interested to know whether the underfloor heating was installed with screed or as a dry construction? This affects the optimal installation height and spacing.
Siamakri
17 Jul 2021 11:47
Palenar schrieb:
I would also like to know if the underfloor heating was installed with screed or a dry construction system?
Thank you for your detailed response! The underfloor heating is embedded in a traditional cement screed. It is a low-temperature heating system, operating at about 35 degrees Celsius (95°F) supply temperature. The flooring is laminate, and the Metod baseboards are planned to be mounted on it. I have noticed that IKEA usually attaches the baseboards directly to the cabinet fronts using clips, but I would prefer not to drill into or damage the laminate floor. I am also looking for advice on this.
Dirkmin
17 Jul 2021 12:32
When installing on screed with underfloor heating, it is important to avoid heat buildup. Therefore, Ikea Metod baseboards should have at least a 5 mm (0.2 inch) gap from the floor. This allows sufficient air circulation without significantly reducing heat output.
- Installation without floor screws is possible by attaching the baseboards to the wall and using a spacer at the bottom.
- Flexible mounting clips or adhesive strips are thus a good solution.
- For corners, a miter joint that can be easily adjusted is recommended to accommodate movements caused by temperature changes.
Important: Do not create a completely airtight seal at the floor to prevent moisture buildup and thermal stress.
reoleon47
17 Jul 2021 18:21
Hey, great topic! I did exactly the same at my place: I used spacers made from rigid plastic clips that you clamp under the Metod baseboards. This provides excellent air circulation and protects your laminate flooring during installation.
Dirkmin schrieb:
Flexible mounting clips or adhesive strips are therefore a good solution.
Exactly! And the installation goes much faster this way and is really enjoyable. Stay flexible with the corners, and everything will fit perfectly! Good luck with it!
