ᐅ How can I best clean grease stains from IKEA Metod kitchen fronts?
Created on: 21 Oct 2019 08:17
Ilyas46
Hello everyone, I am looking for effective methods to improve the cleaning of Ikea Metod kitchen fronts, especially for grease stains. The fronts are usually high-gloss or matte lacquered or laminated, so of course, you want to avoid damaging or making the surface look worse. Currently, I mostly use dish soap with water, but the grease stains are hard to remove completely, especially when they have dried in. I am interested in which cleaning products and techniques really work well without damaging the surface. Are there any household remedies that can be safely used? And what about stronger cleaners or microfiber cloths? It would be great if someone could share their experiences and maybe also tips on the right cleaning frequency. Thank you!
Ilyas46
21 Oct 2019 10:55
Thanks in advance for the tips! It’s interesting that lemon juice is recommended; I would have some concerns about the surface because of that. Are there any alternatives to isopropanol? I want to avoid the fronts dissolving or becoming dull. I’m also wondering if regular polishing or some kind of protective coating can be applied to the fronts to make cleaning grease easier or to make the fronts more durable.
praWarre69
21 Oct 2019 11:20
Sure, you can use denatured alcohol, but with caution. Some people recommend mild vinegar, but it’s not always suitable for painted surfaces because of the acidity. If you want a bit more protection, you could try furniture polish with a wax effect; it makes the surface slightly water- and dirt-resistant – not too often, but once or twice a year works well.
Marion
21 Oct 2019 11:48
Wax or furniture polish can provide more durable protection for the surface. However, first check if it is suitable for foil surfaces. Otherwise, it is better to just clean and keep dry.
nera59
21 Oct 2019 12:17
As a supplement to the topic of protective coatings: For Ikea Metod, I do not recommend waxes or oils because these can quickly leave unsightly streaks on high-gloss laminate surfaces. It is better to use special plastic or surface protection products that are specifically designed for painted or laminated kitchen fronts and do not leave greasy residues. However, it is always important to test first in an inconspicuous area!
Ilyas46
22 Oct 2019 07:43
After the many suggestions, I cautiously treated a small stain with isopropanol yesterday – it worked well, and the surface remained flawless. The microfiber cloth is also very helpful, as already recommended. However, I noticed that when cleaning, you should never get it too wet, otherwise water stains will form. That’s why I keep cleaning to a minimum to avoid any damage. It remains interesting to see if there might be a gentler yet effective solution.
ronti
22 Oct 2019 08:03
Water should be only slightly damp, never dripping wet – this is the most important rule for Metod fronts. Microfiber cloths work really well; often, dry polishing after cleaning is sufficient.
