ᐅ How can I optimize the installation of IKEA Metod kitchen cabinets?
Created on: 29 Jan 2024 08:37
Keposon
Hello everyone, I am planning to install some IKEA Metod kitchen cabinets soon and would like to make the process as efficient and error-free as possible. Specifically, I’m interested in hearing which methods, tools, and organizational tips you would recommend to carry out the installation not only safely but also in a time-saving way—especially for more complex elements like corner units or wall cabinets. I would also like to know about common pitfalls during the installation and how to avoid them. I already have experience with DIY furniture assembly but want to gather best practices this time before I start. Thanks in advance for your detailed tips and shared experiences!
Lucien
29 Jan 2024 15:57
kasan schrieb:
I am also wondering whether it might be useful to build a rough frame on-site before installation or to use adjustable feet to level the cabinets.
I think that’s a good approach, especially since Metod cabinets come with modular feet that can be adjusted in height. These should be used consistently to compensate for uneven surfaces.
To check the wall, I recommend using a spirit level or a laser level, as traditional tape measures cannot accurately capture the degree of unevenness. This way, you can better plan how much adjustment is needed for the cabinets or wall mounting.
Additionally, it is advisable to use connection elements such as locking plates at corners and transitions (which IKEA provides) and to tighten them only lightly at first to allow enough room for adjustments.
sanjon
30 Jan 2024 07:22
I would also recommend not installing doors and drawers on the cabinets immediately after assembly. This way, it is easier to make fine adjustments if necessary.
When attaching the cabinet rails for the drawers, make sure to measure precisely, otherwise everything may stick later on.
Paxton38
30 Jan 2024 10:43
Keposon schrieb:
My issue is mainly that the kitchen has an unusual shape with a corner where two cabinets meet at a 90-degree angle, and the walls are not completely straight.
For cases like this, I recommend the following approach:
- Before installing the individual components, place the cabinets slightly away from the wall and level them using shims and the height-adjustable baseboard.
- Initially, loosely screw the corner cabinets together to allow for flexible adjustments before final tightening.
- If the wall is uneven, you can adjust the wall mounting by using washers at the screw points to compensate for irregularities.
This allows for precise alignment despite irregular walls.
