ᐅ How can I optimize storage space in IKEA Metod tall cabinets when dealing with limited room?
Created on: 19 Oct 2020 08:37
Deori
Deori
19 Oct 2020 08:37
Hello everyone, I am facing the following issue and hope to get your experiences and tips: In my small kitchen, I want to optimize the storage space in the IKEA Metod tall cabinets as efficiently as possible, but I have very limited space. Specifically, these are cabinets with a width of 40 to 60 cm (15.7 to 23.6 inches), which I want to use as efficiently as possible—without taking up much extra room but with a high storage volume. My question is: How can I optimize storage space in IKEA Metod tall cabinets when space is tight, especially regarding the flexibility of shelves, use of internal pull-outs, and additional storage solutions? Are there any proven tricks or products that make access easier while maximizing space? Any advice on modularity or combining different built-in options would also be greatly appreciated. Thanks in advance for your recommendations!
lochen
19 Oct 2020 09:05
Hello Deori, your question is very practical and concerns many people with small kitchens. First of all: In confined spaces, it is crucial to plan Metod tall cabinets in a highly modular way and to use adjustable shelves wherever possible. Installation options such as internal pull-outs or pull-out baskets not only improve visibility but also allow better use of the entire cabinet depth.
- Tip 1: Use internal pull-outs (e.g., from Hettich or IKEA), which allow you to pull out the entire cabinet carcass – this way you also make use of the rear space inside the cabinet.
- Tip 2: Divide the vertical space into several small tiers to make better use of otherwise unused upper areas.
- Tip 3: The inside of doors can be equipped with hanging trays or slim storage containers – perfect for small items.
A combination of drawers and fixed shelves might also be useful to store different items flexibly. If you like, I can provide more examples and measurements later.
LOJOPAR
19 Oct 2020 10:23
lochen schrieb:
Installation options like internal pull-outs or pull-out baskets not only improve organization but also allow better use of the full cabinet depth.
I would like to add to this and offer a structured approach you can follow:
- Step 1: Measure the exact internal dimensions of the tall cabinet, including the height between the shelves.
- Step 2: Plan for adjustable internal pull-outs or baskets that are ideally fully extendable—full-extension pull-outs are the best solution for deeper cabinets.
- Step 3: Use metal or plastic organizers for the larger pull-outs, as these are sturdy.
- Step 4: Small accessories can be sorted with transparent boxes, making optimal use of every corner.
A common mistake is using only wooden shelves, which unnecessarily divide the space into small sections. Flexible, fully extendable units are better, allowing for varying heights of items even on lower levels.
Ultimately, careful planning with precise measurements and flexible components is essential to maximize storage space in tight areas. If you like, I can also provide specific product recommendations that I have used in similar situations.
GALENKU
19 Oct 2020 12:48
LOJOPAR schrieb:
A common mistake is using only wooden shelves, which unnecessarily break up the space into small sections.
Exactly, I would recommend internal pull-out drawers. This way, you can easily access the back areas without awkward stretching. Simple fixed shelves tend to waste space.
draleo
20 Oct 2020 14:11
In addition to the previous discussion, I recommend considering the optimization of storage space in Metod tall cabinets from the perspective of volume utilization and ergonomics.
1. Volume: Since the internal dimensions of Metod cabinets are fixed, large compartment divisions often waste volume. Internal drawers make use of the full depth and allow complete use of the available height by planning compartments with different heights.
2. Ergonomics: For shallow depths, pull-out elements are almost indispensable to easily reach items stored at the back.
3. Additional solutions: Install flat door-mounted organizers and height-adjustable shelves to flexibly accommodate items of different sizes.
4. Customization: Use precise measurements so that exclusive adapters or internal drawers for specialized storage solutions can be installed.
Another tip: For very narrow tall cabinets, also consider other IKEA series with specialized solutions, as they sometimes offer better internal drawers or accessories. Combining different products can further optimize storage.
If you already have specific measurements or a design plan, tailored product recommendations can also be provided.
